mm98
1
Server Version#: 1.18.3.2111
Player Version#: Hosted
The QNAP PMS Intel/AMD 64-bit, download link in PlexWeb is pointing to the wrong file (ext. *.codesigning - 1kb). This is also wrong on https://www.plex.tv/media-server-downloads/
NOTE: Removing .codesigning from the filename, returns the correct file.
yep.
affected users must manually pull the qpkg from here
hopefully Plex folk will fix this soon; it makes them look rather foolish.
Appears to be fixed here.
mm98
4
The plex.tv download page still shows filename with .codesigning here on Intel/AMD 64-bit (QTS-4.3 and newer) …
@OttoKerner, double check your browser’s URL.
ARM packages are correct (i.e., a .qpkg file)
Intel package is not (still the .codesigning textfile)
I hear they’re working on it, but it’ll take a while for things to refresh (esp. if they’re behind some CDN, I suppose…)
Could it be a caching issue? I’m in Europe and I’ve checked all 4 links, they are all correct.
I checked with no local cache in the mix here, and still borken.
so it may be a matter of CDN refresh then.
time will tell?
mm98
8
I’m also in Europe (Denmark) and the link is still incorrect …
mm98
9
Download link is now correct …
system
Closed
10
