I’ve recently added plex media server to my QNAP TS-563. The app center version is v1.13.5.291. I’m currently running the beta v1.15.0. I also tried the current public release. With all versions none of the settings seem to stick. When i restart my NAS or stop plex and restart it wants to setup the server again. Settings like remote access, library scan automatically etc don’t seem to save even though when saving it saves changes have been saved.
Yea definitely signed in. Whilst the settings are active (i haven’t restarted NAS or stopped and restarted plex through app centre) i can access the server via iphone app.
Here are the logs. I stopped the plex server and then started. It opened up with setup again and i changed the remote access, library to auto scan. Plex Media Server Logs_2019-02-19_11-19-51.zip (2.0 MB)
Would you mind making certain, and leaving, you logs in DEBUG logging.
At one point they were in VERBOSE mode… When in VERBOSE mode, I can only see about 2-3 minutes of elapsed time.
Would you mind restarting PMS itself , from app center, and letting it come up fully.
Wait 60-120 seconds after it completes, then grab the logs again.
Rename the file named : /share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Library/Plex Media Server/Preferences.xml to /share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Library/Plex Media Server/Preferences.xml.old, and then restart OMS from the AppCenter
BUT. I found something that said sync settings across devices or something like that… I unticked it and now it’s working! I was able to close it down and re-open and it saved everything fine. Inlcuding the .xml details as above.
I also went in to authorised devices and removed some really old devices one being the NAS last seen 3 years ago… so potentially it was picking up on a config file there?
