I used my QNAP as my Plex server. I want to become a cord cutter so I purchased a HDHomeRun Quatro.
I can watch TV directly from the HomeRun, I can’t seem to get Plex to find it on my QNAP, I’ve even typed in the IP manual. When I install Plex on my PC it will immediately find it. They are both on the same network.
I vent purchased an HDHomeRun Extend to see if it was the machine. No luck there.
Running out of idea’s to figure out the problem.
Anyone else had a similar problem and/or solution?
Edit: From logs I am getting
Plex Tuner Serv[17]: segfault at 58 ip007f117a4bf8a4 sp007f11751a8f70 error 4 in libpthread-2.21.so[7f117a4b0+10] – Count:0
Call Trace – Count:2
Because you have VERBOSE logging enabled, I can’t find what I need in the Server logs. It’s already gone out of the buffer.
Please never enable VERBOSE logging unless requested. DEBUG logging is always more than enough.
I can’t find the libpthread error you did. Where did you find it? Which file?
While this shouldn’t be a problem (I have almost the same configuration),
What are the IP addresses involved, particularly the IP address of the Tuner?
All good. I thought you would be ok there.
I looked back through my journal. The only thing I can think of is the HDHomeRun firmware. Is it up to date?
I’ve tried putting it on my other NIC but it doesn’t seem to find it on that one either. That was my original plan, have a dedicated NIC for the homerun.
QNAP allows both interfaces to serve as a single interface to allow more bandwidth to NAS. This was my cheap way of disabling the other interface for now.
