Cannot find HDHome run even when I manually add IPPlex Media Server Logs_2018-06-29_14-15-32.zip (4.5 MB)
Are you having two interfaces active on the same IP net?
Jun 29, 2018 11:53:12.554 [0x7fa0e7bff700] DEBUG - NetworkService: Browsing on interface 192.168.0.86 on broadcast address 239.255.255.250 (index: 0)
Jun 29, 2018 11:53:12.554 [0x7fa0e7bff700] DEBUG - NetworkService: Browsing on interface 192.168.0.84 on broadcast address 239.255.255.250 (index: 1)
If so, look at Q21 in the QNAP FAQ
The HDHomerun connect is built with two tuners
Not related, I’m talking about your QNAP here!
The IP’s you are looking at here are for the Qnap NAS that has the plex server running on it. The HDHomerun’s IP is 192.196.0.103
I know
Now please answer my question!
The NAS has network ports I’m using three of them presently. Two are agragatted to the 192.168.0.86 and a seperate on 192.168.0.83
so you’re saying that Q21 says I’m asking for problems?
Yes
You have a lot of errors in your log regarding http requests…
Not saying this would solve the issue you raised though, but we need to start with that
And FYI, changed the TAGs of your post to make it show in the QNAP fora’s instead of general
that seems to have taken care of that issue.
Thanks!
