Quality problem (720p)
Dear all,
I have a problem sharing my movie library with my friends.
Indeed, my movies are in 1080p quality (at least) and I can play them perfectly in this quality when I am connected on the SAME network as my Synology NAS.
However, when I watch a movie on my NAS via another network, I am limited to 720p quality (even for 4K movies). This problem is the same with my friends who watch my movies on my NAS remotely (with a different network). I subscribed to a 4.99€ subscription but it doesn’t change anything.
Could you please help me ?
Check the bandwidth settings on the server and on the client.
Plex default client settings for remote streaming are 2 Mbps / 720p.
Server:
Settings → Remote Access + Show Advanced.
Verify both Internet Upload Speed and Limit Remote Stream Bitrate are correct.
Client:
Android Mobile is SettingsQualityRemote Streaming Quality. Others should be similar.
Note: Enabling Automatically adjust quality (if available on the client) results in Plex Media Server transcoding the stream. See https://support.plex.tv/articles/115007570148-automatically-adjust-quality-when-streaming/.
I did all the settings and according to the Plex binder (Plex NAS Compatibility - Google Sheets) my DS220+ NAS server should work with 1080p movies but I can’t.
Can you please tell me your transcoder settings?
Thank you !
I’m not sure what you mean by transcoder settings but I would check the quality setting in the client player apps you are using
Its possible the clients are accessing the sever via Relay which has a 2mbps
limit as well https://support.plex.tv/articles/216766168-accessing-a-server-through-relay/
I don’t think it’s a setting problem because when I use my Plex server to watch my movies but via a different network than the one my NAS server is connected to, I have a problem than the one my NAS server is connected to, I have the problem : I am limited to 720p maximum…
I’m not sure what you mean by that. Clients have remote quality setting which is used when on a different network than the server. That remote quality is defaulted to 720p. Client players have a separate setting for when it on the same network as server which is defaulted to maximum
Sorry, my English is not very good.
I just saw that my server said: Not available outside your local network. I can’t activate it.
So I think that’s probably why.
I’ll check it out
But thank you very much for your help
Ok. then it likely was connecting via relay because remote access was not working.
There is some info here on basic things you can try to fix remote access https://support.plex.tv/articles/200931138-troubleshooting-remote-access/
