Question About Switching to Plex Movie Agent
I updated the agent for my movies to Plex Movies agent by doing the “Upgrade Matching” option which appears to have switched over, but am not sure it has worked properly.
There are no additional agents, local media assets or any other agents I can reorder. Can someone confirm if the agent should have anything listed underneath. I was expecting it to have the same reorder list and option gear icon as other agents.
Server Version#: 1.20.3.3483
All options for the new Movie agent can be found in the properties of the library, on the “Advanced” tab.
The switchover does only happen after you Refresh Metadata of a movie.
If you have added your movies from a network file share per UNC path (\\server\share\folder) I recommend you wait until the server software version 1.20.4 is released.
It will contain a critical bugfix for local movie extras.
@OttoKerner, will this bugfix also address external subtitles as per this post: "Conversion failed. The transcoder failed to start up." message when trying to play videos with external subtitles - #14 by Yaracuy ?
It has something to do with external assets (subtitles) and UNC paths.
