When using PlexConnect will other features on the ATV2 cease to work? Like Disney Jr for example?
Thanks!
Thanks!
No! Just the channel you choose to use to activate plexconnect ( default is Trailers)
Sent from my iPhone using Tapatalk
Thanks. I got it up and running but it seems that the Disney apps aren't loading for me. They'll populate but won't actually load any of the videos. Weird.
How did you install plexconnect on the (jailbroken?) Apple TV itself or a different os/device? If a different os/device if you could provide a detailed report using this template it would help:
https://github.com/iBaa/PlexConnect/wiki/How-to-report-an-issue
Try changing the ip_dns in the settings.cfg from googles (8.8.8.8) to your ISP’s
Try changing the ip_dns in the settings.cfg from googles (8.8.8.8) to your ISP's
Hmm mine are set to google at the moment. I can switch it tho.
Its not jail broken. Its a ATV3. So PlexConnect is running on a buntu box. Let me see what I can get report wise
That didn't work either :\
Time for logs etc then
