I have bought a R730 with 2x8core cpu and 128gb memory. 2x10gbit nic
16x4tb disk with raid h730p controller with 2ssd cache..
What i also want is a GPU to put into this one for hardware transcoding..
Planning to have all my material in 4k, and some clients sometimes need to transcode.
So thats why im planning to install a GPU and make passtrou to the vm that is running plex
Anyone who have tried something like this before and have any GPU suggestions?
there are lots of tesla cards on ebay that i can buy but i cant realy use those?
i have a vmware/esx box that runs a couple of servers and one of them is a plex. I have a gtx geforce 710b that allows for 2 transcode streams. I had to do extra work on getting the pass through to work correctly as if i rebooted the plex server it would reboot the whole host. Had to change the power signs on it. It looks like you have a little extra money in your setup than i do. I would make sure the gpu you go with is esx support. NVIDIA can only do transcode in one direction. Good luck, with your setup.
