Raspberry Pi
Awesome! Now that plex for pi is here, I just need to order my Pi :smiley:
I’m stoked for this!
I have it booting on my Pi. It is however asking for a login. I tried a few standard pi logins with no luck. Any ideas?
Thanks!
plexuser:rasplex
root
Then at command prop type: plexht
I was able to connect to plex and stream videos (even 1080p ones) with this wireless USB adapter
http://www.amazon.com/Edimax-EW-7811Un-Wireless-Adapter-Wizard/dp/B005CLMJLU/
at command-line I typed ā€œwicd-cursesā€ and was able to connect to the SSID of choice and input the wireless password. I also set it to auto connect.
i ve been using normaly xbmc on my pi now i installed plex but i dont get a network connection (via Lan) anyone a idea? anything i have to do?
No need for a driver?!
I have a problem with wicd-curses in the latest Rasplex release;
When I change the authentication setting for my WiFi to "WPA1/2 Passphrase", it doesn't stick/save the setting. It stays at WPA1/2 Hex.
Anyone else seeing this?
http://www.element14.com/community/docs/DOC-44703/l/raspberry-pi-wifi-adapter-testing
Popular drivers included in os.
Also, I have a problem with my Apple USB keyboard, it sends multiple button presses, making it impossible to control Rasplex properly.
It works fine in Raspbmc, so the keyboard is functioning.
I can’t use the Plex iOS app to control Rasplex either, it hangs if I try to navigate.
So pretty much stuck trying to navigate Plex on the Pi right now :slight_smile:
But we do not use the raspberry os ;)?
I didn't need to install drivers for the wifi Usb to be detected.
Can't wait for hdmi cec to be implemented, but for the time being I am using this as the remote. Works great out the box
http://www.amazon.com/Windows-Control-Infrared-Receiver-Ultimate/dp/B00224ZDFY
I've been watching movies and shows all morning and rasplex is awesome. The home menu is a tad laggy but very very usable.
Thanks Dale.
Did you connected it via usb hub or directly to the pi? i find it with lsusb but dont see any wireless network… :confused:
the mce remote receiver and the wireless usb are connected directly to the pi.
Just tested this guy out and here is what i have found,
1080p choppy 720p seems ok
gui usable but slow
channels do not work
other than that, I cant believe how far this has come along in a very short time. I wish I knew half the things you guys know lol
I just donated 25 beers to ya to help out with anymore development, I cant wait until this is finished and runs similar to raspbmc! I will donate more on my next check!
Thanks!!
mmh ok anyone a idea why for me the http://www.amazon.com/Edimax-EW-7811Un-Wireless-Adapter-Wizard/dp/B005CLMJLU/ dont work? at lsusb it is shown but if i wicd-curses it dont find the stick … anyone?
btw apt-get update doesnt work?
Is there any iOS app to control?
If u want to try cec do this.
cd /usr/local/share/XBMC/system<br />
wget http://download.raspbmc.com/downloads/lib/bin/libcec.so.2.0.0<br />
plexht
I have been using it and it works fine.
I’ve uploaded some new skin changes, this gives the option to disable fanart and recently added/on deck. It’s done in a slightly different way than before and I find it actually works better for me, I’d be interested to see if this is the case for people with big libraries.
Instructions:
cd /usr/local/share/XBMC/addons/skin.mediastream
wget https://www.dropbox.com/s/2etl9joiz4d50wb/720p.zip
unzip 720p.zip
Does Airplay only Support Audio?
https://itunes.apple.com/us/app/plex/id383457673?mt=8
