Just donated, just wanted to say thanks.
anywhere a how to install?
for beginners on linuxs and the pi?
Where do you live? US, Canada?
I like modmypi, because they sell cases and everything else you need.
There are probably cheaper places. Newark/element14 is good too, as is bcrobotics.
Also, the quality of the movie shouldn't matter, it plays high def just as well as raspbmc.
Australia. Don’t mind ordering from overseas.
Thank YOU!
i got all of mine from element 14, got them in a few days and im up in Darwin.
http://downloads.element14.com/raspberryPi3.html?isRedirect=true
Hi there, http://blog.srvthe.net/archives/474 is for easy install.
Keep in mind it's still alpha... so stay tuned! There are more improvements to come.
Does this version already have airplay support :)?
Greets
Fabian
If anyone doesn’t mind ordering overseas then CPC/Element 14 make the best Pi’s
I got mine from RS Components.
I am following this project for a while now.
It is awesome!
I just made a small donation, I hope everyone does.
Thank you guys! B)
What skin is he using?
using the mediastream skin from os x pht.
Heh yeah, that's probably a good idea. Look forward to that.
Dale,
I’m doing a new skin and I’m trying to make it use as little resources as possible (no fanart slideshows etc.) - I have the Raspberry Pi in mind.
It should only be a few MB’s when finished. It’s coming along - I have the main menu almost finished, and will start work on the different views soon.
When I have the time, I will try it on your latest PHT for Raspberry Pi image, maybe it will make it run even better than it does now with the default Mediastream skin
Thanks for doing this port, I can’t wait to try it on my Pi in the bedroom.
The install of the latest Rasplex Unstable has been tough. I can’t shutdown because it keeps bugging me for myPlex credentials. Think I’ll wait for 0.1a
This just looks awesome!
Just ssh into it and let it reboot. (I had to set a pass for root before I could ssh into the pi)
And you also have to get the settings XML file and the modified theme for it to work ;) just follow the steps in dale's blog post(s) and it'll work :)
Rasplex 0.1-rc1 alpha released! http://blog.srvthe.net/archives/519
Awesome work guys! About to test it out
Will this be able to use plex plugins like hulu. YouTube and other channels. Just bought two of them. Raspbmc on them now but like plex much better. Keep up the great work. Love the osx skin
