Raspberry PI3 wifi
Good Morning All
I have installed the latest rasplex onto my raspberry pi3.
Only issue i am having is the Wifi is not working.
Please help i am new to raspberry pi.
Go to System Settings, make sure WiFi is enabled, select the correct SSID and connect. You should have set this up on first run through the First Run Wizard.
Okay thanks. will reset the plex or just reload the image back.
Thanks will try tonight.
Thanks NedtheNerd
It worked.
