raspberrypi 2
i agree no menu sounds, pin prompt worked immediately for me but
menu sounds is normally cured once you've setup audio output correctly.
Already tried that :)
Could any of you guys could take a little video of PHT on RPi2, showing navigation speed in menu, in large libraries and during the playback that would be really cool !! Thanks
Gimme 15.
I have just compiled a RPi2 image of OpenELEC 5.0.1 with PlexHT 1.3.6 if anyone is interested in testing PlexHT on RPi2.
Grab image and source code from https://github.com/Kwiboo/OpenELEC.tv/releases
Note: OpenELEC-settings is not included in image.
Hey, how did you do that so quickly when Rasplex team took months to port PHT on RPi1? Is PHT 1.3.6 already ARMv7 compatible? Please enlighten me  :)
Hey kwiboo seemed a little buggy,
1) Didn't have menu sounds ( not exactly an issue haha )
2) Unable to get the PIN prompt to work, re imaged 3 times no luck just sat there with no pin code on the display.
3) Audio compatibility seemed to have no pass through, Not sure if thats correct ?
4) My server disappeared couldn't get it to come back.
Please remember folks, this is not Rasplex but a port of PHT on OpenELEC, and contains no Rasplex optimisations, credit to Kwiboo for getting it to run.
I have tried this and it may appear faster but doesn't seem to be fully utilising the new processor, appears slightly faster due to more memory. There also seems to be quite a lot of functionailty missing and is a little unstable, use at your own risk, I have corrupted two cards already. @Kwiboo, please note that PHT 1.3.6 is still PlexPass only and shouldn't have been used for a public release, you may get Plex Inc on your tail, however, good work.
Regards
the plexpass isn't really an issue. it won't let you login with a non plexpass usually???
If you haven't enabled Plex Home it will let you log in to MyPlex whether you have a PlexPass or not, and you don't have to login to use it locally.
Regards
Regards
Oh I didn't know! :ph34r:  I've seen it with PMS and not letting it work. I figured it was the same.
sorry!
Ive given up trying to do a video sorry guys, I cant get it to connect to my server anymore, corrupts almost every reboot and Pin doesn't work.
Rasplex have posted on their FB that they just received 3 test units and will be working through the weekend.
I ordered a Pi2. Even if it is just a tad faster in menu response than the B, it's already money well spent! ;-)
Verzonden vanaf mijn iPhone met Tapatalk
Where in the USA are people getting the  Pi 2? All I am finding is UK only.
Yes !!
http://www.newark.com/
I ordered mine from modmypi (UK) on Monday and it showed up today.
If you really want Rasplex on your Pi2 then follow this guide for now https://forums.plex.tv/topic/145555-want-rasplex-on-rpi2-try-the-berryboot-method/?p=846065 new Rasplex is cooking at the moment!!!!!!!
Regards
Hey guys, just wanted to reiterate my earlier question: Does anyone know if the Pi2 can output native 24p via its HDMI port?
It does!  :)
Awesome work kwiboo!
I’d love for you to join the project.
I’ve looked at your code, and I think it shouldn’t be hard for us to address together some of the issues being outlined here.
Also, I got ahold of a raspberry Pi 2 yesterday so I’m planning on working through the weekend to get it available.
Cannot wait for this, thank you to everyone who contributes!
