RasPlex 0.1.38 wifi settings not saved
Hi all,
I installed RasPlex 0.1.38 from my MacBook the other day using:
curl -L http://goo.gl/MZEvU -o getrasplex.py
chmod +x getrasplex.py
sudo ./getrasplex.py -b
The auto update didn't work so I lost all my settings. So I tried (re)connecting to to my wifi, which it did, but now every time I reboot RasPlex I have to hook up a keyboard to reconnect to the wifi. RasPlex doesn't remember the settings (SSID, password). Where in the OS does it store those settings? I want to enter them in a/the config file. Is it /storage/.plexht/userdata/guisettings.xml (from the top of my head)? If so, what's the syntax?
Can I browse the kernel.img of my 0.1.37 version? I copied that before installing 0.1.38. I could look at the settings files in that image. If so, how?
Excuse me if this question has already been asked. I did a search on the forum, but didn't find the answer.
Thanks all,
Evert
It’s a known issue with .38
jep same here
Same here but no worries. I’m sure it will get resolved :slight_smile:
It seems this issue is wifi only... any other problems with unsaved prefs?
(https://github.com/RasPlex/RasPlex/issues/28)
Nope. It's only wifi. But still, I'm back to 0.1.37, although I can't get the ssh deamon to work. But that's a different question.
Try to disable and re-enable the service.
Duh. Like I didn't do that already ;)
Maybe a solution here:
http://forums.plexapp.com/index.php/topic/72019-cant-keep-configuration/
The wifi issue is resolved now: https://github.com/R...sPlex/issues/28
And suddenly, after just another restart, ssh works. Yeah!
I have the same issue with wifi and ssh not working.  have tried the above steps to no avail. rolling back to a previous version... hope this gets fixed soon.
Is there a dummy guide to fixing the wifi issue? The info at https://github.com/R...sPlex/issues/28 doesn't really help me out.
The only way is to wait until the next release...
a_wein has fixed this bug and the fix is available in 0.1.40. Closing this topic.
