Rasplex 0.5.1 (Pi2) - Login Plex Home not working
Hi there,
I have the following issue: I installed Rasplex 0.5.1 on my Pi2 and have configured 3 Plex Home users on my server (2 of them have a PIN, the third one doesn't). Switching users on Rasplex works fine, but sometimes when I turn on my TV and - I assume - Rasplex comes back from hibernation (I setup Rasplex to hibernate after x hours) I am being asked which user to logon. If I select a user, only a black screen appears. If I start to enter my PIN, a screen for the PIN appears, but nothing happens after I press enter. Even a restart doesn't help. Same goes for the user without a PIN, just a black screen and nothing happens. Sometimes, after a couple of reboots, it works again.
The Pi2 is connected via LAN, I don't think it's a network issue (loging in/switching users in the Plex Web App works fine).
Any ideas?
Hi there,
Any ideas?
Had a similar problem when using Plex Black Edition skin. Shifting to the standard skin solved the problem...
Aah, thanks for the hint, I am using this skin. I'll give it a try!
