Rasplex 1.0.0 Released!
Except for Hi-res Apple Lossless music files that skips, everything is super smooth. Very proud of you guys, good work. :slight_smile:
@chenks said:
am i able to kick off the update via ssh?
Go to Preferences->System->Updates and select Pre-Release Channel, then Check for Updates.
Regards
@chenks said:
that’s not what i asked.
i know it can be done from the menu.
i asked if it can be done via ssh.
No
Regards
No different to PlexHT, Plex Media Player, Plex Media Server, etc, are you going to have a go at Plex Inc next?
Regards
@chenks said:
so unattended updates are not supported.
bit of a major fail there i think.
You must be fun at parties.
OT:
Are you planning to update the bug fixes on the short term or in a later release?
Hopefully minor release should be out soon to fix the downmix issue.
Regards
With a little bit of work it should be possible to update over ssh, see my reply in the Initiate update remotely using SSH? topic.
Updating to the new version by uploading the .tar to /storage/.update/ and rebooting the Pi worked perfectly over ssh.
Thanks for a great release and a great product overall. Fixed problems with .mp3s stuttering :slight_smile:
@henkall said:
I am having issues with the cec double keypress. Are there anything I can do about that?
I am using a Phillips screen.
It worked fine on 0.7.1.
Edit:
Just to point out this works fine on the Raspberry Pi 2 with PMP and the Raspberry Pi 1 with Rasplex 0.7.1
I have the same issue with double presses on CEC. Actually also using a Philips tv. It worked as inteded in 0.7.1. Not sure which option to change in the CEC settings that could affect this. Its not every remote control press that resolves to a double.
/cheers
Adeban
Great job with this release, works fine for me !
BUT, i was hopping you’ll add full support for Hifiberry digi card, enabling their use for music AND movies… Tell me you will do it some day…
Hi ! Great job on this release, server discovery seems to be performing way better now.
I have noticed that the powersaving function seems to be broken. I have it set to shutdown after 20mins, but it restarts my Rpi instead??
Cheers
There is no power saving function for RPi’s, hardware doesn’t support it.
I think it should be removed as an option.
Regards
Regards
?? It was working just fine in the previous versions of rasplex and just triggers the shutdown of the system. I don’t get why RPI would not support this?
Hello,
First, thanks for your great job.
I just intalled this new update and I have some troubles with CEC. Play, pause and forwards are not working well. If the TV is off and turn on the pi, then this buttons are working. But if the pi is already running and i turn on the tv, all the buttons of my remote are working except the buttons at the bottom of the remote (Play, pause, forwards, stop…)
I have a Panasonic 55CX700 and before this update it was working well.
Any idea?
Hello,
my problem with the new image is following: I have plugged the remotepi board (2015). I did use it already with the 0.7.1 and it run very stable. Since the update to 1.0.0 I have problems with shutting down the raspberry pi2. I hit the power off button. What happens than is, the green LED turns to red and blinks. This is the same behavior as before. But it does not power off then. It seems that something is waiting for something.
Then I ssh into rasplex and do execute shutdown -h now. Then the board powers down finally.
Any idea?
Best regards,
Frank
Verified the bug I logged on the previous build as confirmed fixed.
You can now jump to any location in a library using the jumped and it will populate the content image covers correctly now. No major issues for me so far.
Getting better and better per release. :slight_smile:
Having a problem where some of my videos are awfully quiet. I turn up the audio on my TV to 100 and I can still barely hear it. Others are fine. This didn’t happen with 0.70 (I never updated to 0.71).
Know issue, filed on Github, will be fixed in next release, only affects downmixed 5.1/7.1 audio, 2.0 audio is not affected.
Regards
I’ve been looking forward to the 1.0.0 because of the Game Emulation I thought there’d be. Am I overlooking it, or has it been postponed? Might just be a little impatient :slight_smile:
What game emulation? Where did you get that from?
Regards
