There’s quite a noticeable delay (a quarter second?) between the RasPlex screen and Hyperion. It hasn’t always been there. I started noticing it a couple of months ago. I don’t think it’s a hardware issue–the same Hyperion settings work fine for RetroPie. I saw that someone posted a similar issue on the Hyperion forum hyperion-project.org/threads/leds-reacting-with-delay.446/ and was wondering if anyone else noticed this? I have a Raspberry Pi 3 and upgraded to 1.7.2 without any luck, unfortunately.
Whoops, meant 1.7.1.
Never mind, looks like my issue was that the Kodi-Checker option was enabled in my hyperion.config.json and pointing to the wrong IP address. My guess is that RetroPie doesn’t look at that setting, and my IP address changed a couple of months ago when I bought a new router.
Welp, I’m an idiot, hope this helps someone else.
@ofuangka said:
Never mind, looks like my issue was that the Kodi-Checker option was enabled in my hyperion.config.json and pointing to the wrong IP address. My guess is that RetroPie doesn’t look at that setting, and my IP address changed a couple of months ago when I bought a new router.Welp, I’m an idiot, hope this helps someone else.
Appreciate you coming back and sharing the answer. Would you please mark your post as the answer so other people may find help with the same problem easier.
