I have RasPLEX on the Pi. perfect.
My Mac Mini runs as server.
The Mac Mini goos to sleep when it is not used. I think green :)
When RasPlex starts I see the folders of the media. so fare so good.
When I do not use the RasPlex for a hour or so the server is in sleep and the media is gone from the screen.
I have to wake the server before the media is show again in RasPlex.
In the past I used the add-on wake on LAN but it looks like this one is not available for RasPlex.
Does one of you has a solution for this.
I don't mind my server go to sleep and having to wake from sleep when RasPlex becomes active again or when I start scrolling through the lines.
But having to reach for a second remote to wake the server :unsure:
I could be a setting.
please let me know.
thanks.
a_wein
2
You’re searching for a SleepProxy-Server… (currently just available on Apple-hardware, built into mdnsresponder)
But you could just code some bash scripts and use OpenELEC startup script hooks as a workaround.
You're searching for a SleepProxy-Server… (currently just available on Apple-hardware, built into mdnsresponder)
Thanks for the replay but I do not understand <_<
In Openelec I can download the plugin wakeonlan. this is not available in RasPlex.
Would it be possible to get the wake on Lan plugin installed on RasPlex. :mellow:
thanks,
a_wein
4
It should be possible to install it manually (it may be necessary to switch to the confluence skin).
