Hi All,
Running Rasplex official 1.0.0 and for some reason it’s not outputting anything but stereo. I’ve enabled 7.1 surround, DTS, and AC3 in the audio configuration.
Here’s some config info
RasPlex:~ # tvservice -a
PCM supported: Max channels: 8, Max samplerate: 192kHz, Max samplesize 24 bits.
AC3 supported: Max channels: 6, Max samplerate: 48kHz, Max rate 640 kb/s.
DTS supported: Max channels: 7, Max samplerate: 96kHz, Max rate 1536 kb/s.
DTS_HD supported: Max channels: 8, Max samplerate: 192kHz, Max rate 8 kb/s.
RasPlex:~ # egrep RasPlex /etc/*issue*
RasPlex (official) Version: RP-1.0.0
RasPlex git: 4994e38300dcf501c585a9335dedb631485b3e81
Let me know if I can pull any additional configuration information.
FYI: Hooking up my laptop and playing the same files with VLC works over the same receiver channel and cable.
