RasPlex Releases
This forum will have information specific to new releases
Rasplex 0.1.24 (released as bleeding edge)
  • Merged OpenELEC head for various fixes (thanks a_wein)
  • Tweaked clocks to medium-high levels, seems optimal
  • Autoupdate notifications (thanks a_wein)
  • Enabled compile time optimizations
  • No debug symbols
  • New splash screen
  • Faster UI
Rasplex 0.1.25 (released as bleeding edge)
  • Hot fix to stop network spamming /DOS issue
RasPlex 0.1.26 (released as bleeding edge):
  • upstream update to openelec 3.0 rc5
RasPlex 0.1.27 (uploaded as bleeding)
  • Reduced default overclocking due to reports of SD filesytem corruption and boot issues
  • HEAD merge with upstream PlexHT/XBMC.
  • Lots of OMX (playback) patches - may resolve playback issues
  • Substantial changes occurred with CEC. May fix it, or completely break it - ye be warned.
  • GUI seems faster after initial caching (esp loading fanart, thumbs, browsing).
RasPlex 0.1.28
  • Minor bugfix
RasPlex 0.1.29
  • Head merge with PHT 9.97
RasPlex 0.1.30
  • Candidate fix for BSOD
  • Added update addon to preferences
  • Localization support
RasPlex 0.1.31
RasPlex 0.1.32
  • Update to OpenELEC 3.0.0
    • Improved GPIO-IR support (see Wiki)
    • Some more smaller changes and fixes
  • Reduced logging
    • Debug logging is now disabled by default
    • Minor speed improvements
RasPlex 0.1.33
  • Merged latest OpenELEC branch
    • Added support for new OpenELEC settings dialog, rebranded as "RasPlex settings"
    • Much better wifi support
    • First time startup wizard
  • Known Issues:
    • Cosmetic problems with skin (using blue instead of orange highlights)
    • Wizard is quite broken, should be reworked a lot, but works "enough" for now.
RasPlex 0.1.34
  • Removed precaching, which seems to substantially improve performance and caching speed on RPi. TY LongChair and Tobias :)
RasPlex 0.1.35
  • Major speed improvements
    • Fanouts actually work now! (Recently added / on deck, etc), around 1-2s latency
    • Loading Movies / home screen is much faster (3-4s instead of 15-20)
    • Loading fan art / thumbnails is much faster
  • Bug fixes
    • Fixed blue highlighting to be orange
    • other odds and ends.
RasPlex 0.1.36
  • HD artwork by default
  • Speed improvements
  • iOS Remote fixes
  • Dramatically improves stability of 256 MB Pis for playback and navigation, unstable during initial caching still :(
  • SSH Fixes
Special thanks to LongChair for contributing most of the work for this release, Dale's been busy with his actual day job.
RasPlex 0.1.38 and 0.1.39:
  • There are known issues with this versions and they should not be used - Just use 0.1.37 or 0.1.36 for now.
RasPlex 0.2.0
  • Bug fixes for:
    • Airplay
    • Wifi settings
    • System stability
    • Region setting
  • Major code cleanup of openelec
  • Major code cleanup of PlexHT
  • OpenELEC 3.0.6
  • Updated settings widget / dialog
  • Updated setup wizard
Special thanks to a_wein!!!
Notes:
  • The hostname changed to rasplex by default!!
  • The builtin updater is broken, please use 0.2.1.
RasPlex 0.2.1
  • Bugfix for rasplex-updater
RasPlex 0.2.2
  • Support for multiple RasPlex on one network
  • PlexHT-Logfile is now available via the logfiles smb-share
RasPlex 0.3.0
  • Update to OpenELEC 3.2.1
It updates it's base system to the latest version of OpenELEC. Overall performance should be improved and several bugs should be fixed.
We're already working on the next big release (0.4.0) which will pull the latest PlexHT into RasPlex.
RasPlex 0.3.1
  • Update to OpenELEC 3.2.2 (should fix wifi issues)
  • Updated RasPlex updater (supports new update system now)
All systems running 0.3.0 will update itself to 0.3.1 if auto-update is enabled (which is the default). Manual updates can be triggered by using the RasPlex updater and selecting "bleeding" or "stable" as target release.
RasPlex 0.4.0-rc2 has been released!
Check out the release notes and download it at https://github.com/RasPlex/RasPlex/releases/tag/0.4.0-rc2
If you are running 0.4.0-rc1, you should be able to update by simply selecting the "prerelease" channel, and selecting "check for updates". Then just let it install, and reboot. Please let us know if you have issues with updating, as it's a new system we are testing out (and while we've tested it thoroughly, very nervous as this is the first time it'll be running live!)
As always, please report bugs at tiny.cc/rasplex-bugs, not on facebook :)
A couple notes:
We've added a troubleshooting / known workarounds page:
Please check this before filing bugs. If you are experiencing the calibration issue on updating from a previous release, please do a fresh install.
You can view the issues that were closed by this release here:
And the issues that we're working on for rc3 here:
