Hello,
I have a rasplex client running 2.1 version. Much faster to navigate through the sections, great job!!!
I have another pi running a wheezy to play with.
Issue: when the wheezy boy is connected, rasplex client can’t see my plex server (ubuntu/0.98).
I already modified the /etc/hotsts:
127.0.0.1 localhost rasplex
127.0.0.1 localhost raspmpd
They are both accessible through ssh but rasplex is blind. No sections showing up…
Nota: rasplex is accessible as a airplay device, i can stream content from my ipad/gn2 to it.
If someone has an idea… He would be my savior.
Both pis are connected with ethernet, network scanners can see both of them on a different ip address.
Thks
Valyno
Solved!
I had to format my raspbian. So at first boot, rasp-config showed up. I modified the unit name and tadaaa both pi are on the same network and rasplex can see all my sections from the server…
