Rasplex won't sign in
Suddenly I am unable to sign into myplex on my Raspberry pi 2 running 0.7
At the log in screen where you would normally be prompted with a pin it is blank
If I manually type my user id and password i set a spinning wheel and nothing happens
When I turn my tv on I just get search on the left hand side
HELP PLEASE
Troubleshooting
Rebooted router and power line adapters
Changed network cable
Reimaged micro sd
Which version of PMS are you running. There were a lot of fixes for network issues in 9.12.5 thru 9.12.8
Regards
I had the exact same issue with 0.7.0 using wifi via a panda wireless pau05 usb unit. I had to flash to 0.6.0, sign-in, then upgrade from withing the app to 0.7.0
Hi, thank you both for getting back to me.
Sorry I’m a newbie to all this, I’m running 9.12.4 (says its upto date)
I just erased and re-imaged to 0.6.0 and still getting the same problem, i can’t sign in just get to the sign in page then it doesn’t give me a pin and just a spinning wheel.
I can access my server on iOS devises, not tried other tv/powerline just yet.
When you boot up Rasplex before attempting to sign in to MyPlex in Preferences->System do you see anything other than Search? You should see your libraries and be able to play content without signing in (but you won’t be able to use anything that requires a PlexPass as you login is used to validate).
If you can’t then there is an issue with your Network, have you turned on debugging and looked at the logs?
Regards
Also, check in System Settings->Network, that you are connected to your Network.
Regards
Hi guys
I found the problem, you were right and it is a network problem with my powerline adapters
Just had to found a work around until I can reset the adapters
Thank you all your help everyone
@lil.spikey.dude said:
Hi guys
Can you please mark this as answered, thanks.
I had similar issue, but in my case system time was wrong.
.plex.direct:32400/] failed: Peer certificate cannot be authenticated with given CA certificates
01:05:21 T:1607074896 WARNING: CCurlFile::FillBuffer [192-168-1-5.hhgggggg
I added an ntp server and voila it’s working fine.
I realize this was old, but thank you adriankoooo, In my case the ntp server wasn’t set and after the time change everything stopped working.
thx 4 that. this solved my login issue as well
My issue was date/time related as well. I lost power and RasPlex had a bad date. Normally this wouldn’t be an issue but the internet is still down so it couldn’t hit the NTP servers for the right time. All I had to do is ssh in and run:
date --set=“2015-11-09 18:02:00”
(Putting in the current date of course)
And everything popped back up and now I can watch my plex media until the Internet is back.
Problem with no on board RTC, you can get a cheap one here Mini RTC Module for Raspberry Pi | The Pi Hut
Regards
I had the same problem too, I manually added a ntp time server (as suggested above) and was then able to login with plex userid etc.
I’ll chime in to say that adding the NTP fixed my RPi2 running RasPlex 0.7.1, too.
Hi
I have similar problem.
How can i set rigth time?
Thx
