Rasplex 0.6.0 - Won't login
Flashed Rasplex 0.6.0 on a new SD card for my Raspberry Pi since the original card shot craps.  Everything seems to be working great with the exception that it will not login to Plex.  I have tried entering my User & Password using the Manual button, too, but it just sits there and spins and never comes back.
I have a Plex server here at the house with some movies and I can see and play them just fine.  My son has a Plex Server at his home and I can see it and the movies thru my Android phone and when I connect to the Rasplex for viewing it says it cannot access the movies.  I am assuming it is because the Rasplex is not logged in.
I didn't have this issue with 0.4.?  Did anyone else have a problem not being able to login and figure out why??
Same issue. It spin, nothing else.
Changing the sdcard solved it for me.
Changing the SDcard to a higher spec or just a new one?
Mine is new and still does not login,
I loath having to buy a new one grrr
hi,
i have same problem with last version (1.0.4), have u solved?
Did you make sure the time / date on the RPi is correct? SSL based encryption usually doesn’t work if the time is significantly wrong.
Yes, i setted Italy/roma
Setting a time zone doesn’t mean the time can’t be wrong, the system has to have an internet connection to get synced via NTP, please check the time on the RPi.
Really, this should be set to the free NTP.org Pool by default in my opinion. I’m going to open a feature request. :slight_smile:
[EDIT]
Done.
how can i do this check?
SSH in to the RPi and enter the command ‘date’
Regards
Thx
I checked and I have two hours before the actual.
Now I Wed May 11 21:17:33 UTC 2016, but really this time is 2 hours before (now is 23:17)
how can I set the correct time?
Thx
Hi
I have ever jan 01 00:0:00 UCT 1970
Can i set permanently date time in RPI?
Thx
See https://forums.plex.tv/discussion/218416/rasplex-cant-find-server-no-internet-connection#4 and https://forums.plex.tv/discussion/218416/rasplex-cant-find-server-no-internet-connection#6
Can I also suggest that you keep this subject in one topic, you are posting the same thing in two different topics.
Regards
