Rasta balancing on top of the TV
Not to be outdone, Bella on top of the TV too…
They’re both judging you haha
Very likely…
With such a name, I expected her to look more like this:
Her full name is Rastafarian…
No risk of the tv toppling over?
Rasta weighs about 8 lbs, Bela about 5
TV is about 80-90 lbs… Tv does not even shake.
I also have 2 shelf rails mounted on the back (where the wall hanging screws go), and have a wire frame shelf mounted on the back of the TV. That is what the center channel speaker you see is mounted. The whole rig is placed flush with the wall. While it is not mounted to the wall, since it is in contact it stabilizes everything,.
