Server Version#: 1.31.0.6654
Player Version#: Plex for Windows 1.64.2.3546-5107ec40
So in trying to replace the default “Recently Added” recommendation for movies (and other libraries), I discovered a bug where the recommendation reappears on the homescreen even though it’s disabled.
Steps to reproduce:
- Disable a default Plex “Recently Added X” recommendation in Libraries in settings
- Have at least one other recommendation in that same library enabled
- Play something from the homescreen, ( I used continue watching), in full view
- Stop playing
You should see the recently added recommendation reappear on the homescreen, even though it is still disabled in the Libraries settings.
Gif of bug: https://i.imgur.com/2Wa3S3S.mp4
Edit for clarification:
The first “recently added movies” is a smart collection I made, at first I did think having the same name was causing the bug, so i tested it without it and in different libraries and had the same problem.
https://i.imgur.com/mY57xeI.mp4
Your Gif looks like it adds another " Recently Added Movies" that was already there doubling it up which certainly looks like a bug but i can’t reproduce. Did you have Recently Added TV disabled?
Possibly I cannot reproduce because I am on the latest server beta 1.31.1.6733 ( I am also on a Mac not Windows so will ask others if they can repro when they are online)
Sorry, I edited my post for clarification.
Do you have “Merge Recently Added” enabled at the bottom of the Manage Libraries settings? I was able to repro with that enabled but wanted to confirm if you have it enabled, and if you disable it, does it stop happening.
I didn’t think of that, I did have “Merge Recently Added” enabled,
I just disabled it and tested, that did fix the bug,
then I re-enabled it and the bug came back.
So I guess that’s the cause, nice find!
Unfortunately merging recently added TV is a pretty nice feature that I’d probably choose over having a custom “Recently Added Movies”, at least until it’s fixed.
Thanks for your quick help in figuring it out.
Here’s a clearer gif showing the bug behavior:
