Server Version#: 1.40.2.8395
Player Version#: 1.92.1.140-8e1f68f5
For some reason, it is showing Recently Added TV twice, and it is showing things that are NOT in that specific library. I’ve checked the mobile app and the browser app, and the issue is not present there.
Recently Added is supposed to merge items from all libraries of a certain type by default. So it is to be expected that it shows items from different libraries.
There is an unsolved bug: if you have several libraries with different metadata agents, the merging fails – resulting in two hubs appearing.
You can disable that merging here
Settings - [Server name] - Manage - Libraries
(check box at the bottom)
See if you like that more.
