Recent plays crashes PlexAmp over CarPlay
Server Version#: I updated about a week ago. Curiously PlexDash does not show the server version.
Player Version#: 4.1.0
Recent Plays crashes PlexAmp in CarPlay. Everything else works.
This is on a fresh install. Anyone else seeing this problem?
Sorry to clutter up the forums with this but there’s no in-app error reporting.
no clutter at all, this is the right place to report!
just to clarify, when you try to browse Recent Plays, or is it crashing when you dive into a specific item?
FWIW I haven’t been able to reproduce an issue, either browsing to that area or browsing into each Recent Play item. Will definitely need more specifics here.
Hi @elan ,
The crash occurs when simply tapping on Recent Plays, it never gets to a list.
I reproduced the issue and collected the PlexAmp logs. They are attached. Thanks for the fast response!
Plexamp-Logs-2022-03-26-1.zip (140.3 KB)
Thank you for the logs! I was able to reproduce and fix. The issue is around some items in that list which refer to a server which it doesn’t know about anymore, if you remove them it’ll work around the crash for now.
Cool! Will give it a shot and report back. Thanks!
@elan Hey, that worked. I migrated servers a couple months ago and I guess there were a few strays left over. Thanks again!
Glad to hear!
