Has been working reliably but recently made the mistake of signing out of MyPlex to log into another account. Now I’m unable to sign into any account whatsoever. Any attempts at logging into MyPlex via the settings page results in an infinite buffering symbol with plexconnect showing:
May 15,2018 12:54:17 WebServer: File Not Found:
Traceback (most recent call last):
File “D:\Downloads\PlexConnect-master\WebServer.py”, line 244, in do_GET
XML = XMLConverter.XML_PMS2aTV(PMSaddress, self.path + query, options)
File “D:\Downloads\PlexConnect-master\XMLConverter.py”, line 241, in XML_PMS2aTV
(username, auth_token) = PlexAPI.MyPlexSignIn(parts[0], parts[1], options)
File “D:\Downloads\PlexConnect-master\PlexAPI.py”, line 667, in MyPlexSignIn
response = urlopener.open(request).read()
File “C:\Python27\lib\urllib2.py”, line 435, in open
response = meth(req, response)
File “C:\Python27\lib\urllib2.py”, line 548, in http_response
‘http’, request, response, code, msg, hdrs)
File “C:\Python27\lib\urllib2.py”, line 473, in error
return self._call_chain(*args)
File “C:\Python27\lib\urllib2.py”, line 407, in _call_chain
result = func(*args)
File “C:\Python27\lib\urllib2.py”, line 556, in http_error_default
raise HTTPError(req.get_full_url(), code, msg, hdrs, fp)
HTTPError: HTTP Error 500: Internal Server Error
I have also tried to whitelist the IP address of my ATV3 in PMS so that I can use it without authorization but any attempts to do so have only resulted in plexconnect showing:
May 15,2018 12:53:38 PlexAPI: PlexGDM - looking up Plex Media Server
May 15,2018 12:53:38 PlexAPI: ***
May 15,2018 12:53:39 PlexAPI: GDM: Servers discovered: 1
May 15,2018 12:53:39 PlexAPI: Servers (local, plex.tv, MyPlex): 2
May 15,2018 12:53:40 PlexAPI: No Response from Plex Media Server
May 15,2018 12:53:40 PlexAPI: We failed to reach a server. Reason: Unauthorized
May 15,2018 12:53:40 PlexAPI: Traceback:
File “D:\Downloads\PlexConnect-master\PlexAPI.py”, line 441, in getXMLFromPMS
response = urllib2.urlopen(request, timeout=20)
File “C:\Python27\lib\urllib2.py”, line 154, in urlopen
return opener.open(url, data, timeout)
HTTPError: HTTP Error 401: Unauthorized
Hard-coding the IP of my PMS and harcoding has yielded no results. Hard-coding the login info for MyPlex does result in my account being shown as logged in on the settings page but then no server is found and clicking discovery/hardcoding into the settings file does has not worked so far.
Can anyone please help?
