Normally when I add a Library, I click on the plus right of the Server. I then select type (Music) and then rename it as Music Rock. When I hit the tab key to continue the Next button is grayed out and
doesn’t allow me to continue.
Refresh the web app in your browser. (usually with F5)
Then try again.
I tried your method and also shutdown everything and started it up again. I still can’t get
past the name change. I also noticed that when I open Plex, I can’t see the music libraries on the navigation sidebar except when I click the More button on the bottom.
Which web app did you use? app.plex.tv
If you are missing a library on the side bar, pin it.
https://support.plex.tv/articles/customizing-plex-web/
https://support.plex.tv/articles/customizing-the-apps/
I’m using the app in conjunction with Synology NAS.
I’m not missing a library. I having trouble creating a library. This started after latest update. Is there a method of reverting back to the previous update?
Uninstall the package from Package Center
Install the version you would like (manual install)
Where do I locate the older version of plex?
What do you have ? I can help with certain versions from my personal g-drive
(It’s a good idea to keep at least 1-2 versions you’re happy with )
ChuckPA,
I update to PlexMediaServer-1.18.0.1944-f2cae8d6b-x86_64. I don’t know the version number, but it was the one prior to this update.
Ok. That’s what I needed to know… Which processor type.
ChuckPA,
Thanks. It now works perfectly.
David
