I will try using your naming and see if it makes any difference
It shouldnât. Yours is already close to mine.
8:15 is working right on my Shield too.
PLEX for Win 10: v 1.22.1.4200
NVShield Pro 2019 PLEX: v8.15.1.23620 (2d06f04a)
NVShield Pro 2019 SW : v8.2.2(32.6.509.0)
I made a MOVIE to demonstrate exactly what I am seeing. I did a full reset of the hubs and started recording. After showing all is fine, I then did a manual edit of the hubs and home screen. Clearly something is still rotten in Denmark!
That was a boring movie.
I have no idea why we are all getting different results. It doesnât make any sense at all.
I wonder what would happen if you removed and added the app again?
Fixes for the separated Recently Added rows not having library names, and an option for those who want to combine Recently Added is coming. Though I do not have an ETA it should be soonishâ˘ď¸
Hehe, thatâs the second time Iâve seen that word today.![]()
I hope youâre rught.
Boring?! Did the special effects not load correctly?
I donât get why we are having different results, either. What I really donât understand is why the RA changes after going to a manual edit of the home screen.
@BigWheel - I appreciate PLEX and I appreciate you communicating with us. I really do.
Fixes coming for the separated RA is great! But it does not excuse or distract from the fact that what is already compiled and released should work properly and as expected. Going to a manual edit of the home screen should not cause radically different behavior of the home screen.
On the NVShield Pro, the home screen doesnât give the name of the movie library for RA, but it does for the RA within the actual library itself. This also works for the Windows version, as well.
I honestly would appreciate bugs being worked out before new features are introduced.
