Recommended panel unavailable
Hello,
Currently i encounter an issue with the “Recommended” panel in the Mobile App and the Smart TV APP.
But i have a working acces to my library, i can navigate and play video file normally in the “library” panel
I tried to look at the log files on the web-player:
And in my android log files:
05-23 105208.266  i [pms] 192.168.5.2155815 - GET logging
05-23 105215.224  i [ContentSectionNavigation] Navigating to path hubssectionslibrarysections1
05-23 105215.224  i [UserAction] Tab selected, item key (hubssectionslibrarysections1), name (Recommended)
05-23 105215.243  i [Boot] FragmentWithBehavioursDelegate took 0ms to run create behaviours.
05-23 105215.244  i Fetching [methodGET] https192.168.5.2332400hubssectionslibrarysections1count=20&includeEmpty=1&includeExternalMetadata=1&includeLibraryPlaylists=1&includeRecentChannels=1&includeStations=1&includeTrailers=1&includeTypeFirst=1&libraryHubsOnly=1&X-Plex-Token=...jTW6
05-23 105215.264  e Error fetching https192.168.5.2332400hubssectionslibrarysections1count=20&includeEmpty=1&includeExternalMetadata=1&includeLibraryPlaylists=1&includeRecentChannels=1&includeStations=1&includeTrailers=1&includeTypeFirst=1&libraryHubsOnly=1&X-Plex-Token=...tml
05-23 105215.265  i Fetching [methodGET] https192.168.5.2332400hubssectionslibrarysections1count=20&includeEmpty=1&includeExternalMetadata=1&includeLibraryPlaylists=1&includeRecentChannels=1&includeStations=1&includeTrailers=1&includeTypeFirst=1&libraryHubsOnly=1&X-Plex-Token=...jTW6
05-23 105215.271  e Error fetching https192.168.5.2332400hubssectionslibrarysections1count=20&includeEmpty=1&includeExternalMetadata=1&includeLibraryPlaylists=1&includeRecentChannels=1&includeStations=1&includeTrailers=1&includeTypeFirst=1&libraryHubsOnly=1&X-Plex-Token=...tml
05-23 105215.285  i [Boot] FragmentWithBehavioursDelegate took 0ms to run create behaviours.
05-23 105222.488  i [pms] 192.168.5.2155825 - GET logging
This problem happen on my Local network (Wi-Fi) and also from outside with 4G.
I tried to uninstal/reinstal the Server/Mobile app/ TV App
Could you please help me with this issue ?
Thanks,
NAS Model/Version#: QNAP TS-453Bmini / 4.4.2.1310
Server Version#: 1.16.6
Mobile Player Version#: 8.0.2.17816(23329cc1)
Up, i still need help if someone have an idea ?
