Recorded Episodes not Showing
Since the last server update, a show that I have set to record everyday shows up in recently added television (has the carot and number of new episodes) but if I select it, it says there are no episodes. If I go into the library I created for recorded tv it does not list the show. If I check the file location on the computer, they are there. I also noticed the show information it matched with does not match the epg data. Windows 10 with HDHR connect.
