Recorded HD From HDHomerun
Plays back on my pc though very jittery on my amazon tv and won’t fast forward. All my other high resolution rips play fine…
Is there a fix for this? Does anybody else have the same problem?
me too… not sure what the cause is
Same issue here too. I’ve been recoding the recordings as MP4’s just using PlexDVR to capture. Can also remove the extra time start and end too.
It must be a plex issue if I can play the files back on a computer ok…
they also play fine remote via the webplayer… go on there must be a fix?
ideas? please
