I have two TV libraries. One is a static library, one is a (mostly empty) recorded TV library. Plex is setup to record from my OTA tuner into the second mostly empty recorded TV library. Some shows do not appear in the Recorded TV library. I can see and play them in file view, but not library view. I’ve correlated it to if the show exists in my static TV library in some form, it won’t show it in the recorded TV library.
Assuming this is a bug. Or is there something I should check?
