Server Version#: 1.19.1.2645
Tuner Make/Model: HDHomeRun Connect Quatro/HDHR5-4US
Guide/Lineup name:
Using XMLTV?:
Channel number/Name: 20
I have a channel which has a weak signal. I record one show every sunday. The 90% the signal channel is strong enough to Plex to record it. But, sometimes like yesterday, the signal is weak and the channel is down. Plex gave me the notification that it couldn’t record the show and it is fine. But, if I check my Plex server the recording notification in the status is still there (even 12 hours later)
It is the same notification when the record is actually happening. I know that it is not the case and the only way to get rid of that it is restarting my Plex server.
I could imagine that it is simple bug when the records fails, but the status is not changed and because the record never ends, then the status is never changed.
