Recording on +1 hour channels ignored
I have an odd issue. When I schedule a UK recording using channel 076: QUEST+1 for a programme currently being broadcast on channel 012: QUEST, the recording produced is a partial recording from the QUEST channel. The Fact that I selected the upcoming broadcast on QUEST+1 is ignored. This also applies to other +1 hour channels.
Has anybody come across this behaviour? My sever is hosted on a Linux Mint box, details below.
Server Version#: 1.20.1.3252
Tuner Make/Model: HDHR5-4DT
Guide/Lineup name: Freeview Granada OTA Broadcast
Using XMLTV?: No
Channel number/Name: 012 QUEST / 076 QUEST+1
Try going into the advanced settings when you schedule it to record, near the bottom is an option to limit to channel, make sure you select the +1 here
As far as i know the DVR records based upon show/episode, so when it looks to start the recording it will find the non +1 channel first (if the episode is still airing on it) , and record that
Perfect. Thanks for the fast response. Really appreciate it. I think it might well finally be ready to release into the family. :grinning: Good tip I found yesterday applicable to Live tv dvr, turn off Transcode interlaced Live TV in advanced settings on client. In my case, fire stick hd.
Cheers, Paul.
