DVR Scheduling Bugs
Server Version#: 1.19.4.2935 (running on a WD-PR4100)
Player Version#: 4.37.1
Tuner Make/Model: HDHomeRun
Guide/Lineup name: Broadcast TV Nashville OTA Broadcast
Using XMLTV?: No
Channel number/Name: 4.5 WSMVDT5 (CIRCLE)
The Grand Ol’ Opry airs live at 7PM Central Time (US) each Saturday night on 4.5 WSMVDT5 (CIRCLE). It re-airs on the same channel at 8PM. (back to back airings). This is a standard definition channel. The show re-airs at 10:35PM on channel 4.1 on Sundays (the following day). This is an HD channel.
Problem #1: If I set the show to record “new airings only” and “prefer HD” then it will record the 10:35PM showing on channel 4.1 on Sunday. And it skips recording the SD event on Saturday night. I don’t mind if Plex re-records the episode on Sunday night to get an HD version, but I don’t want it to skip the SD recording on Saturday night.
Problem #2: To get around problem #1, I try limiting the recording to a certain time. The time provided in the dropdown are off by 1 hour. If I select 8pm, it records the 7pm show. If I select 9pm, it records the 8pm show. There is either some sort of time-zone or DST bug when it lets me pick the preferred time.
Here are the logs for issue #1:
Jul 04, 2020 09:34:54.023 [0x7f48c3159700] DEBUG - Subscription: Episode ‘Opry’ airs on channel 4.5 at 2020-07-11 19:00:00
Jul 04, 2020 09:34:54.026 [0x7f48c3159700] DEBUG - Subscription: Episode ‘Opry’ airs on channel 4.5 at 2020-07-11 20:00:00
Jul 04, 2020 09:34:54.028 [0x7f48c3159700] DEBUG - Subscription: Episode ‘Opry’ airs on channel 4.5 at 2020-07-13 10:00:00
Jul 04, 2020 09:34:54.031 [0x7f48c3159700] DEBUG - Subscription: Episode ‘Opry’ airs on channel 4.5 at 2020-07-13 14:00:00
Jul 04, 2020 09:34:54.033 [0x7f48c3159700] DEBUG - Subscription: Episode ‘Opry’ airs on channel 4.5 at 2020-07-13 19:00:00
Jul 04, 2020 09:34:54.035 [0x7f48c3159700] DEBUG - Subscription: Episode ‘Opry’ airs on channel 4.5 at 2020-07-15 20:00:00
Jul 04, 2020 09:34:54.038 [0x7f48c3159700] DEBUG - Subscription: Episode ‘Opry’ airs on channel 4.5 at 2020-07-15 23:00:00
Jul 04, 2020 09:34:54.040 [0x7f48c3159700] DEBUG - Subscription: Episode ‘Opry’ airs on channel 4.5 at 2020-07-16 10:00:00
Jul 04, 2020 09:34:54.043 [0x7f48c3159700] DEBUG - Subscription: Episode ‘Opry’ airs on channel 4.5 at 2020-07-16 15:00:00
Jul 04, 2020 09:34:54.045 [0x7f48c3159700] DEBUG - Subscription: Episode ‘Opry’ airs on channel 4.5 at 2020-07-16 18:00:00
Jul 04, 2020 09:34:54.047 [0x7f48c3159700] DEBUG - Subscription: We want a premiere, and ‘Opry - Brad Pasiley and Keb’ Mo’ is an old airing, ignoring.
Jul 04, 2020 09:34:54.047 [0x7f48c3159700] DEBUG - Subscription: We want a premiere, and ‘Opry - Opry’ is an old airing, ignoring.
Jul 04, 2020 09:34:54.048 [0x7f48c3159700] DEBUG - Subscription: No match in the library for ‘Opry - The Oak Ridge Boys, Sara Evans and Mark Wills’, grabbing.
Jul 04, 2020 09:34:54.088 [0x7f48c3159700] DEBUG - DVR:NewSchedule: Between 2020-07-04 19:00:00 and 2020-07-04 20:00:00 on channel 4.5: ‘Opry - The Oak Ridge Boys, Sara Evans and Mark Wills’
Jul 04, 2020 09:34:54.090 [0x7f48c3159700] DEBUG - DVR:NewSchedule: device 0 tuner 0 airing 2 between 2020-07-05 22:35:00 and 2020-07-05 23:35:00 on channel 4.1: ‘Opry - The Oak Ridge Boys, Sara Evans and Mark Wills’
Jul 04, 2020 09:34:54.090 [0x7f48c3159700] DEBUG - Grabber: Scheduling ‘Opry - The Oak Ridge Boys, Sara Evans and Mark Wills’ for timed grab at 2020-07-05 22:35:00 (in 133206 seconds)
And here are the logs for Issue #2:
(Note that I pick 7pm in the UI, but the server selects the 6pm showing)
Jul 04, 2020 09:37:07.882 [0x7f48f1c8c700] DEBUG - Subscription: Episode ‘Opry’ airs on channel 4.5 at 2020-07-11 19:00:00
Jul 04, 2020 09:37:07.885 [0x7f48f1c8c700] DEBUG - Subscription: Episode ‘Opry’ airs on channel 4.5 at 2020-07-11 20:00:00
Jul 04, 2020 09:37:07.887 [0x7f48f1c8c700] DEBUG - Subscription: Episode ‘Opry’ airs on channel 4.5 at 2020-07-13 10:00:00
Jul 04, 2020 09:37:07.890 [0x7f48f1c8c700] DEBUG - Subscription: Episode ‘Opry’ airs on channel 4.5 at 2020-07-13 14:00:00
Jul 04, 2020 09:37:07.892 [0x7f48f1c8c700] DEBUG - Subscription: Episode ‘Opry’ airs on channel 4.5 at 2020-07-13 19:00:00
Jul 04, 2020 09:37:07.895 [0x7f48f1c8c700] DEBUG - Subscription: Episode ‘Opry’ airs on channel 4.5 at 2020-07-15 20:00:00
Jul 04, 2020 09:37:07.897 [0x7f48f1c8c700] DEBUG - Subscription: Episode ‘Opry’ airs on channel 4.5 at 2020-07-15 23:00:00
Jul 04, 2020 09:37:07.900 [0x7f48f1c8c700] DEBUG - Subscription: Episode ‘Opry’ airs on channel 4.5 at 2020-07-16 10:00:00
Jul 04, 2020 09:37:07.902 [0x7f48f1c8c700] DEBUG - Subscription: Episode ‘Opry’ airs on channel 4.5 at 2020-07-16 15:00:00
Jul 04, 2020 09:37:07.905 [0x7f48f1c8c700] DEBUG - Subscription: Episode ‘Opry’ airs on channel 4.5 at 2020-07-16 18:00:00
Jul 04, 2020 09:37:07.907 [0x7f48f1c8c700] DEBUG - Subscription: We want a premiere, and ‘Opry - Brad Pasiley and Keb’ Mo’ is an old airing, ignoring.
Jul 04, 2020 09:37:07.907 [0x7f48f1c8c700] DEBUG - Subscription: We want a premiere, and ‘Opry - Opry’ is an old airing, ignoring.
Jul 04, 2020 09:37:07.908 [0x7f48f1c8c700] DEBUG - Subscription: We want a premiere, and ‘Opry - Opry’ is an old airing, ignoring.
Jul 04, 2020 09:37:07.909 [0x7f48f1c8c700] DEBUG - Subscription: No match in the library for ‘Opry - The Oak Ridge Boys, Sara Evans and Mark Wills’, grabbing.
Jul 04, 2020 09:37:07.948 [0x7f48f1c8c700] DEBUG - DVR:NewSchedule: Between 2020-07-04 19:00:00 and 2020-07-04 20:00:00 on channel 4.5: ‘Opry - The Oak Ridge Boys, Sara Evans and Mark Wills’
Jul 04, 2020 09:37:07.949 [0x7f48f1c8c700] DEBUG - DVR:NewSchedule: device 0 tuner 0 airing 6 between 2020-07-09 18:00:00 and 2020-07-09 19:00:00 on channel 4.5: ‘Opry - The Oak Ridge Boys, Sara Evans and Mark Wills’
Jul 04, 2020 09:37:07.949 [0x7f48f1c8c700] DEBUG - Grabber: Scheduling ‘Opry - The Oak Ridge Boys, Sara Evans and Mark Wills’ for timed grab at 2020-07-09 18:00:00 (in 462173 seconds)
A fix has already been produced for that and will get through the release process for inclusion in a future version of Plex Media Server,
