Recording save location missing
Having issues whenever i try and record something from the guide that it only shows Video/movie locations rather than TV library. normally it defaults to my “TV Programmes” library
Server Version#: 1.30.2.6563
Tuner Make/Model: xteve/hdhr quadro
Guide/Lineup name: xmltv
Using XMLTV?: yes
Whether Plex wants to stick the recorded file into a “movie” or a “tv show”-type library depends on the information in the EPG (which in your case is imported from the XMLTV file).
If the scheduled airing is marked as a tv show episode, Plex allows you to record it into a “tv show” library.
If not, you will only get “movie” (or “Other Videos”) -type of libraries to choose from.
That was my understanding of it too. So it looks like the epg provider isnt showing that info/tag in the XML. Have a feeling I’m going to have to find another provider then :frowning:
Do you specifically what tags plex is looking for in the XML EPG? I may speak to the provider and see if they can include the tags
I am not familiar with the XMLTV specification. But I think what you see in this post is a tv show episode: XMLTV sports teams tags not working
Maybe some additional info in here: EPG: Season incorrectly identified
But I’m sure there is a better documentation of the XMLTV format around on the interwebs somewhere.
Do you know of any good EPG providers for UK tv?
Sorry, no. What’s wrong with Plex’s EPG?
I’m using combined sources and plex doesnt allow for a mix of XML and Plex Guides for multiple tuners
MY one bug bear with Plex Live TV. You can use either Plex Guides or xml guides but not a combination of the two
