Refreshing data channel guide takes many hours
Hello,
When I add a new TV Tuner, refreshing data channel guide take more than 5 hours to get completed.
You can find .xml here: https://www.xmltv.fr/guide/tvguide.xml
Using Kodi, it takes one minute.
Is there a way to improve that?
Thank you
Turn off enhanced guide
I believe this is a recent problem or bug – I’ve used the enhanced guide for a long time and only noticed it started happening recently, so I disabled it. Glad it helped.
Issue has been reported.
Was a backend problem and it should be fixed now if you’d like to turn the Enhanced back on.
