Refreshing metadata and/or analyzing large library
I’m almost done scanning a 30tb music/movies/tv library and I was planning on doing an ‘analyze’ and and ‘refresh metadata’ for good measure once i was done since some metadata are missed and just a few files don’t play properly.
How long would this take?(about as long as the initial scan?)
What should i expect?
Can i just click analyze then refresh right after each other or do i have to wait?
How many items have been indexed ?
I ask because if it just finished, don’t rush it.
PMS will collect up the list of items to pull metadata for. It may not be complete.
Size is not the factor here. Item count, and how well named, determines how long it takes.
I can match and pull metadata for 11TB of television (10203 files) is about 20 minutes over a 40 Mbps service but also be advised, my media is perfectly curated.
i have a feeling our media is similarly curated
thanks for the rough estimate
curious, is there a way to get the items indexed count?
also, the issue from yesterday has been resolved. i had to repeatedly and repeatedly try refreshing but it eventually worked.
also, any reason i dont have the ‘plex pass’ role on this forum?
  1. Re PlexPass role. I see your PlexPass went active recently. You might still be running on the old login token.
  2. Sign out and back into the forum itself.
  3. If that doesn’t make it visible, I will ask the admin to look.
Regarding how to find the number of files indexed.
A good rough count and, if perfectly curated, accurate:
find /media-dir-1 /media-dir-2 /media-dir-n -type f -print | wc -l
18925 is the number of files indexed
26tb
thank you
ok my library is 100% done scanning but for some reason refuses to get metadata for a few tv series
Plex Media Server Logs_2019-08-02_20-28-54.zip (2.9 MB)
what are some of the name it refuses, exactly as you have the file names please? Also please show your structure for these
i’ll get others but here is one of them
i had to ‘fix match’ and chose themoviedb for it to work, but it wasn’t working otherwise
Not entirely the best naming
Not bad but if I may suggest better and per Plex best practices ?
This will refresh the best (quickest) because there is no ambiguity.
Ambiguities creep in on series like “The Flash” and “The Flash (2014)”. Adding “(1996)” by default guarantees deconfliction. Adding it to the name (best practice) makes each match an atomic operation with TheTVDB (all needed info is from the given file name)
[chuck@lizum Season 01.293]$ pwd
/vie/tv/Krypton (2018)/Season 01
[chuck@lizum Season 01.294]$ ll
total 30101220
drwxrwxrwx 2 chuck chuck       4096 Aug  2 20:44 ./
drwxrwxrwx 5 chuck chuck       4096 Aug  2 21:43 ../
-rw-r--r-- 1 chuck chuck 2939256771 May 27  2018 Krypton (2018).S01E01.Pilot.mkv
-rw-r--r-- 1 chuck chuck 2845337236 May 27  2018 Krypton (2018).S01E02.House of El.mkv
-rw-r--r-- 1 chuck chuck 3494429253 May 27  2018 Krypton (2018).S01E03.The Rankless Initiative.mkv
-rw-r--r-- 1 chuck chuck 3897631612 May 27  2018 Krypton (2018).S01E04.The Word of Rao.mkv
-rw-r--r-- 1 chuck chuck 2068413086 May 27  2018 Krypton (2018).S01E05.House of Zod.mkv
-rw-r--r-- 1 chuck chuck 2958575329 May 27  2018 Krypton (2018).S01E06.Civil Wars.mkv
-rw-r--r-- 1 chuck chuck 2814670191 May 27  2018 Krypton (2018).S01E07.Transformation.mkv
-rw-r--r-- 1 chuck chuck 2714160349 May 27  2018 Krypton (2018).S01E08.Savage Night.mkv
-rw-r--r-- 1 chuck chuck 3223595422 May 27  2018 Krypton (2018).S01E09.Hope.mkv
-rw-r--r-- 1 chuck chuck 3867510089 May 27  2018 Krypton (2018).S01E10.The Phantom Zone.mkv
[chuck@lizum Season 01.295]$
