Refreshing the Guide Crashes during the Initializing Step
Server Version#: 1.19.3.2793
Player Version#: N/A
Tuner Make/Model: HDHomeRun EXTEND
Guide/Lineup name: Broadcast TV Minneapolis-St. Paul OTA Broadcast
Using XMLTV?: No
Channel number/Name: All
Nothing has recorded successfully since 5/11. When I went into the Live TV section, there was no guide data. I tried repeated refreshes and none would get past initialization before crashing. I tried restarting Plex multiple times and also tried deleting and readding my DVR multiple times. Nothing has been successful in getting the guide to load. I turned on debug logging, and I’m seeing errors like the following prior to the guide refresh failing:
May 16, 2020 17:22:46.933 [0x70000e139000] DEBUG - Activity: updated activity 1704845a-f966-4a8d-8e9a-411c1509f43f - completed 5.0% - Refreshing guide data
May 16, 2020 17:22:46.933 [0x70000e139000] DEBUG - HTTP requesting GET https://epg.provider.plex.tv/grid?beginsAt<=1590235200&channel=5cab3c635c4035001d5493b1&endsAt>=1589630400&X-Plex-Api-Token=xxxxxxxxxxxxxxxxxxxx
May 16, 2020 17:22:46.990 [0x70000e139000] ERROR - Error issuing curl_easy_perform(handle): 7
May 16, 2020 17:22:46.990 [0x70000e139000] WARN - HTTP error requesting GET https://epg.provider.plex.tv/grid?beginsAt<=1590235200&channel=5cab3c635c4035001d5493b1&endsAt>=1589630400&X-Plex-Api-Token=xxxxxxxxxxxxxxxxxxxx (7, Couldn’t connect to server) (Failed to connect to epg.provider.plex.tv port 443: Connection refused)
May 16, 2020 17:22:46.990 [0x70000e139000] ERROR - EPG: received HTTP response of -7 from request to https://epg.provider.plex.tv/grid?beginsAt<=1590235200&channel=5cab3c635c4035001d5493b1&endsAt>=1589630400&X-Plex-Api-Token=xxxxxxxxxxxxxxxxxxxx
May 16, 2020 17:22:46.990 [0x70000e139000] DEBUG - HTTP requesting GET https://epg.provider.plex.tv/grid?beginsAt<=1590235200&channel=5cab3c635c4035001d5493b1&endsAt>=1589630400&X-Plex-Api-Token=xxxxxxxxxxxxxxxxxxxx
May 16, 2020 17:22:47.043 [0x70000e139000] ERROR - Error issuing curl_easy_perform(handle): 7
May 16, 2020 17:22:47.043 [0x70000e139000] WARN - HTTP error requesting GET https://epg.provider.plex.tv/grid?beginsAt<=1590235200&channel=5cab3c635c4035001d5493b1&endsAt>=1589630400&X-Plex-Api-Token=xxxxxxxxxxxxxxxxxxxx (7, Couldn’t connect to server) (Failed to connect to epg.provider.plex.tv port 443: Connection refused)
May 16, 2020 17:22:47.043 [0x70000e139000] ERROR - EPG: received HTTP response of -7 from request to https://epg.provider.plex.tv/grid?beginsAt<=1590235200&channel=5cab3c635c4035001d5493b1&endsAt>=1589630400&X-Plex-Api-Token=xxxxxxxxxxxxxxxxxxxx
May 16, 2020 17:22:47.043 [0x70000e139000] DEBUG - HTTP requesting GET https://epg.provider.plex.tv/grid?beginsAt<=1590235200&channel=5cab3c635c4035001d5493b1&endsAt>=1589630400&X-Plex-Api-Token=xxxxxxxxxxxxxxxxxxxx
May 16, 2020 17:22:47.077 [0x70000e139000] ERROR - Error issuing curl_easy_perform(handle): 7
May 16, 2020 17:22:47.077 [0x70000e139000] WARN - HTTP error requesting GET https://epg.provider.plex.tv/grid?beginsAt<=1590235200&channel=5cab3c635c4035001d5493b1&endsAt>=1589630400&X-Plex-Api-Token=xxxxxxxxxxxxxxxxxxxx (7, Couldn’t connect to server) (Failed to connect to epg.provider.plex.tv port 443: Connection refused)
May 16, 2020 17:22:47.077 [0x70000e139000] ERROR - EPG: received HTTP response of -7 from request to https://epg.provider.plex.tv/grid?beginsAt<=1590235200&channel=5cab3c635c4035001d5493b1&endsAt>=1589630400&X-Plex-Api-Token=xxxxxxxxxxxxxxxxxxxx
May 16, 2020 17:22:47.077 [0x70000e139000] WARN - EPG[cloud]: Failed to load EPG.
May 16, 2020 17:22:47.077 [0x70000e139000] DEBUG - Database: Shutting down.
May 16, 2020 17:22:47.077 [0x70000e139000] DEBUG - Captured session 0.
May 16, 2020 17:22:47.077 [0x70000e139000] DEBUG - Captured session 1.
May 16, 2020 17:22:47.077 [0x70000e139000] DEBUG - Captured session 2.
May 16, 2020 17:22:47.077 [0x70000e139000] DEBUG - Captured session 3.
May 16, 2020 17:22:47.077 [0x70000e139000] DEBUG - Captured session 4.
May 16, 2020 17:22:47.092 [0x70000d056000] VERBOSE - WebSocket: processed 1 frame(s)
May 16, 2020 17:22:47.131 [0x70000e139000] DEBUG - EPG[cloud]: Total time to load EPG was 43.9 (HTTP details cached 2.5%, CloudFlare grid cached: 100.0%, 3 HTTP errors)
May 16, 2020 17:22:47.131 [0x70000e139000] DEBUG - Activity: Ended activity 1704845a-f966-4a8d-8e9a-411c1509f43f.
May 16, 2020 17:22:47.167 [0x70000dda4000] ERROR - Error issuing curl_easy_perform(handle): 7
Nothing I do seems to make this work. Any advice would be helpful. It looks like there are some failed connection attempts, but an HTTP response of -7 isn’t even a valid HTTP status code.
I have had the same issue recently. I have to restart the app 3-5 times to get it to actually refresh the guide and anytime I do a rescan.
HDHomerun Connect Quatro
Thanks for the suggestion, but it didn’t work for me. I just restarted 5 or 6 times in a row, and I didn’t see it get any farther than 3%. I was seeing it get quite a bit further yesterday when I was deleting ~/Library/Application Support/Plex Media Server/Plug-in Support/Databases/tv.plex.* when I had the server down between restarts.
Something must’ve crashed hard on the computer. It’s working just fine after a reboot of the machine. Guess I should’ve tried that earlier.
