Could you take a look if something on your end is an issue for me as well? I have had intermittent issues the past week and remote access has just been completely down for me now the past couple days
@aberdeen8 your server has a certificate that was actually new today so not related to that. Would likely need to see the server logs assuming you have done things like restart your server and router and such. You can message them to me if you don’t want to post them here
Will DM them shortly. Thanks!
So it looks like your server may still be trying to use the old installed cert instead of the new one that was assigned yesterday.
In the plex data folder in the Caches folder there is a file called cert-v2.p12
Stop the server> delete that file >then start the server back up
There was a user with a similar issue recently that had to delete the entire caches folder and if you do that I would back it up the folder someplace else first before deleting so you can put it back if things go wacky after starting server back up. ( remember to not have server running while doing this)
I tried both deleting the cert and then deleting the whole cache folder after backing up and the problem still persists. I will dm you logs again. Anything else that I can try?
I am sure youre busy with other things as well but I just wanted to bump this to see what else might be happening? Ive tried everything and read through numerous forums etc.
Sorry I have not forgotten about this but I am a bit stumped so trying to get some other eyes on it.
What do you have set for Client Network? The top option in the Network Settings of server? If not please set it to IPv4 only. (,restart server afterwards)
Be aware that Plex has been unstable for a few weeks now.
At least Remote Access.
Latest issue a few hours ago.
Any issues on your end for me? just got around to switching the server pc over to ethernet instead of wifi and im playing hell trying to get remote access back.
