Hi
So i have 2 Plex Servers. For some reason i can get one t use remote access but not the other.
I think i need to change the port on my second server.
So i need to change it to use 32401 instead of 32400.
I have made the change in the settings but not sure if the second Plex server is actually using port 32401.
What an i missing please?
Rob
Did you create the port forwardings in your router manually or do you rely on the automatic creation per uPnP?
So i have done a port forward to both. So i know how to do that.But for some reason.
Private 192.168.1.6 : 32400 - Public xxx.xxx.xxx.xxx : 32401
but as you can see the public port is not the same as the private.
If i try to set both to use 32400 the router says conflict.
So how to i make my private ip address use port 32401.
That is my problem
The private port number will always be 32400.
It is the public port that matters.
So:
plex server #1: 32400 public -> 32400 private
plex server #2: 32401 public -> 32400 private
On both servers, under Settings - Server - Remote access, you’ll have to tick the checkbox ‘Manually specify public port’ and put in the public port assigned to this particular server.
Already done that…
Then verify that the forwardings are working and the ports are open by using
http://www.canyouseeme.org/
put in 32400 and 32401 and test with each
so 32400 works but 32401 does not.
It turns on for a few seconds and then turns off.
So stuck,
even tried other ports but nothing
Disregard the remote access status within Plex for now.
Did you perform tha accessibility test with canyouseeme?
