Remote access impossible
Server Version#:
I’m unsure why, but whatever I have tried (including using a VPN) has failed to fix the issue of Plex refusing remote access.
This was the only reason I set this server up so I’m extremely disappointed. At this point I have decided to cancel Plex pass and switch to a different service altogether.
Has anyone else found it impossible to remotely connect?
What have you tried to get it setup?
When you forwarded a port, without vpn, did it show open? https://canyouseeme.org/
Could you hit your server via its public ip and the port you forwarded?
What ISP do you have? Are you DoubleNAT/CGNAT?
