Server Version#: 1.43.5.11079
Player Version#: 2026.20.0
Hello, I have a Plex Pass.
My issue is with accessing the library on my Plex server—which is installed on a QNAP NAS—using the Plex Android app on my smartphone.
This problem only occurs when I’m away from home.
Remote access works fine; for example, I can access it from my smartphone using Firefox (https://app.plex.tv/desktop). But I can’t access it using the Android app.
I’ve disabled strict SSL validation.
I’ve been looking for a solution but can’t find one.
Go to the cache directory in the plex media server folder, is there a certificate.p12 file? If so, stop plex, rename it certificate.p12.old and start plex back up. It should download cert-v2.p12. Test access from your Android device.
Thanks, but the certificate.p12 file doesn’t exist.
The cert-v2.p12 file does exist, though. I renamed it to test, and it regenerates just fine.
/share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Library/Plex Media Server/Cache/cert-v2.p12
What’s strange is that if I open app.plex.tv/desktop from my smartphone, I can see entries in Plex Media Server.log.
But from the Android app, I can access my profile and my account…
When I try to refresh the connection to the server, there are no entries in the logs.
Hopefully someone can take a look at the logs, may want to disable verbose and grab them again.
So on your local network, the android app connects fine?
Assume you’ve already signed out of the app, deauthed it in your account settings under authorized devices, and uninstalled/reinstalled just to give it a full reset?
The app logs may be helpful as well since it seems to be specific to the Android app.
