Remote Access issues for Mobile devices + streaming issues
Hello Group, sorry this is going to be a bit of a long post but i see the trend that more details are better than fewer.
I am Running a dedicated Unraid Server and Plex Media server with a PFsense dedicated router.
About 4 weeks ago after updated all of these programs/apps/servers i have started facing a lot of problems on external streaming. some devices buffer constantly, others (like a mobile) wont even start the stream. I have read SO many post and none apply…
The BIGGEST indicated is the security… if i turn the PLEX server’s Secure connections to DISABLED, and change the mobile setting to Always allow insecure connections… EVERYTHING works!
The Details
Server Version#: UNRAID 6.8.3
Player Version#: PLEX 1.19.5.3112
Router Version#: PFsense 2.4.5-RELEASE-p1
I have a 500mbs(down)/200mbs(up) connection (speed test confirmed)
My Check list
Port forward 32400
Enable NAT reflection (tried both Pure Nat and NAT + Proxy)
DNS resolver custom option:
server:
private-domain: “plex.direct”
server:
private-domain: “unraid.net”
Disable server support for IPv6 (on Plex server)
I even spent DAYS to start a new test Plex server with a revers proxy (https://plex.mydomain.com)… set all the security up…SSL/HTTPS… and it worked!!! but… absolutely no change… meaning its not the encrypted connection thats the issue…
What i am asking here is for some wisdom…
LOG for streaming without secure connection (REMOTE CONNECTION) (MOBILE APP)
Aug 02, 2020 10:52:12.783 [0x1459010e8700] Debug — Auth: authenticated user 1 as myusername
Aug 02, 2020 10:52:12.783 [0x1458d1fff700] Debug — Request: [2.48.41.129:30025 (WAN)] GET /library/metadata/17033?includeChapters=1&includeLoudnessRamps=1&includeMarkers=1&includeRelated=1 (12 live) GZIP Signed-in Token (myusername)
Aug 02, 2020 10:52:12.790 [0x1458d1fff700] Debug — It took 0.000000 ms to retrieve 107 items.
Aug 02, 2020 10:52:12.791 [0x1458d1fff700] Debug — We’re going to try to auto-select an audio stream for account 1.
Aug 02, 2020 10:52:12.791 [0x1458d1fff700] Debug — Selecting best audio stream for part ID 36778 (autoselect: 0 language: en)
Aug 02, 2020 10:52:12.791 [0x1458d1fff700] Debug — We’re going to try to auto-select a subtitle.
Aug 02, 2020 10:52:12.791 [0x1458d1fff700] Debug — Audio Stream: 81207, Subtitle Stream: -1
Aug 02, 2020 10:52:12.796 [0x1458d1fff700] Debug — It took 0.000000 ms to retrieve 107 items.
Aug 02, 2020 10:52:12.827 [0x1459010e8700] Debug — Auth: authenticated user 1 as myusername
Aug 02, 2020 10:52:12.827 [0x1458d3dfe700] Debug — Request: [2.48.41.129:29852 (WAN)] GET /video/:/transcode/universal/decision?audioBoost=100&autoAdjustQuality=0&directPlay=1&directStream=1&directStreamAudio=1&fastSeek=1&hasMDE=1&location=cellular&maxVideoBitrate=200000&mediaBufferSize=209664&mediaIndex=0&partIndex=0&path=%2Flibrary%2Fmetadata%2F17033&protocol=&session=3b6a60fbae2ea0dc-com-plexapp-android&subtitleSize=100&videoBitrate=200000&videoQuality=100&videoResolution=3840x2160 (13 live) GZIP Signed-in Token (myusername)
Aug 02, 2020 10:52:12.827 [0x1458d3dfe700] Debug — Found session GUID of 3b6a60fbae2ea0dc-com-plexapp-android in session start.
Aug 02, 2020 10:52:12.829 [0x1458d3dfe700] Debug — TranscodeUniversalRequest: using augmented profile Android
Aug 02, 2020 10:52:12.829 [0x1458d3dfe700] Debug — Downloading document http://127.0.0.1:32400/library/metadata/17033?includeBandwidths=1&offset=-1&X-Plex-Incomplete-Segments=1&X-Plex-Session-Identifier=3b6a60fbae2ea0dc-com-plexapp-android
Aug 02, 2020 10:52:12.829 [0x1458d3dfe700] Debug — Auth: authenticated user 1 as myusername
Aug 02, 2020 10:52:12.835 [0x1458d3dfe700] Debug — It took 10.000000 ms to retrieve 107 items.
Aug 02, 2020 10:52:12.836 [0x1458d3dfe700] Debug — We’re going to try to auto-select an audio stream for account 1.
Aug 02, 2020 10:52:12.836 [0x1458d3dfe700] Debug — Selecting best audio stream for part ID 36778 (autoselect: 0 language: en)
Aug 02, 2020 10:52:12.836 [0x1458d3dfe700] Debug — We’re going to try to auto-select a subtitle.
Aug 02, 2020 10:52:12.836 [0x1458d3dfe700] Debug — Audio Stream: 81207, Subtitle Stream: -1
Aug 02, 2020 10:52:12.839 [0x1458d3dfe700] Debug — Streaming Resource: Adding session 0x1458d409b710:3b6a60fbae2ea0dc-com-plexapp-android which is using 28294kbps of WAN bandwidth. Used is now 28294kbps
Aug 02, 2020 10:52:12.839 [0x1458d3dfe700] Debug — Streaming Resource: Added session 0x1458d409b710:3b6a60fbae2ea0dc-com-plexapp-android
Aug 02, 2020 10:52:12.839 [0x1458d3dfe700] Debug — Streaming Resource: Reached Decision id=17033 codes=(MDE=1000,Direct play OK.) media=(id=34116 part=(id=36778 decision=direct play protocol=
streams=(Video=(id=81206 decision= width=3840 height=1600) Audio=(id=81207 decision= channels=0 rate=0))))
Aug 02, 2020 10:52:12.840 [0x1459010e8700] Debug — Completed: [2.48.41.129:29852] 200 GET /video/:/transcode/universal/decision?audioBoost=100&autoAdjustQuality=0&directPlay=1&directStream=1&directStreamAudio=1&fastSeek=1&hasMDE=1&location=cellular&maxVideoBitrate=200000&mediaBufferSize=209664&mediaIndex=0&partIndex=0&path=%2Flibrary%2Fmetadata%2F17033&protocol=*&session=3b6a60fbae2ea0dc-com-plexapp-android&subtitleSize=100&videoBitrate=200000&videoQuality=100&videoResolution=3840x2160 (13 live) GZIP 12ms 3917 bytes (pipelined: 1)
Aug 02, 2020 10:52:12.871 [0x1458d1fff700] Debug — It took 0.000000 ms to retrieve 160 items.
Aug 02, 2020 10:52:12.882 [0x1458d1fff700] Debug — It took 0.000000 ms to retrieve 142 items.
Aug 02, 2020 10:52:12.889 [0x1458d1fff700] Debug — We’re going to try to auto-select an audio stream for account 1.
Aug 02, 2020 10:52:12.889 [0x1458d1fff700] Debug — Selecting best audio stream for part ID 36771 (autoselect: 0 language: en)
Aug 02, 2020 10:52:12.889 [0x1458d1fff700] Debug — We’re going to try to auto-select a subtitle.
Aug 02, 2020 10:52:12.889 [0x1458d1fff700] Debug — Audio Stream: 81165, Subtitle Stream: -1
Aug 02, 2020 10:52:12.891 [0x1458d1fff700] Debug — We’re going to try to auto-select an audio stream for account 1.
Aug 02, 2020 10:52:12.891 [0x1458d1fff700] Debug — Selecting best audio stream for part ID 36755 (autoselect: 0 language: en)
Aug 02, 2020 10:52:12.891 [0x1458d1fff700] Debug — We’re going to try to auto-select a subtitle.
Aug 02, 2020 10:52:12.891 [0x1458d1fff700] Debug — Audio Stream: 81104, Subtitle Stream: -1
Aug 02, 2020 10:52:12.891 [0x1458d1fff700] Debug — Selecting best audio stream for part ID 17180 (autoselect: 0 language: en)
Aug 02, 2020 10:52:12.891 [0x1458d1fff700] Debug — Audio Stream: 35303, Subtitle Stream: -1
Aug 02, 2020 10:52:12.892 [0x1458d1fff700] Debug — We’re going to try to auto-select an audio stream for account 1.
Aug 02, 2020 10:52:12.892 [0x1458d1fff700] Debug — Selecting best audio stream for part ID 36752 (autoselect: 0 language: en)
Aug 02, 2020 10:52:12.892 [0x1458d1fff700] Debug — We’re going to try to auto-select a subtitle.
Aug 02, 2020 10:52:12.892 [0x1458d1fff700] Debug — Audio Stream: 81098, Subtitle Stream: -1
Aug 02, 2020 10:52:12.892 [0x1458d1fff700] Debug — Selecting best audio stream for part ID 36767 (autoselect: 0 language: en)
Aug 02, 2020 10:52:12.892 [0x1458d1fff700] Debug — Audio Stream: 81142, Subtitle Stream: -1
Aug 02, 2020 10:52:12.897 [0x1459012e9700] Debug — Completed: [2.48.41.129:30025] 200 GET /library/metadata/17033?includeChapters=1&includeLoudnessRamps=1&includeMarkers=1&includeRelated=1 (13 live) GZIP 113ms 20796 bytes (pipelined: 1)
Aug 02, 2020 10:52:13.132 [0x1459010e8700] Debug — Auth: authenticated user 1 as myusername
Aug 02, 2020 10:52:13.132 [0x1458d1fff700] Debug — Request: [2.48.41.129:29784 (WAN)] GET /library/parts/36778/1572313911/file.mkv?autoAdjustQuality=0&hasMDE=1&location=cellular&mediaBufferSize=209664 (14 live) Signed-in Token (myusername) (range: bytes=0-)
Aug 02, 2020 10:52:13.137 [0x1458d1fff700] Debug — Content-Length of /data/Film/Top Films/A.Movie.i.own2008/A.Movie.i.own2008.mkv is 11401044458 (of total: 11401044458).
Aug 02, 2020 10:52:13.255 [0x1458d3dfe700] Debug — Request: [127.0.0.1:34408 (Loopback)] GET /identity (16 live) Signed-in
Aug 02, 2020 10:52:13.255 [0x1459010e8700] Debug — Completed: [127.0.0.1:34408] 200 GET /identity (16 live) 0ms 398 bytes (pipelined: 1)
Aug 02, 2020 10:52:13.268 [0x1459010e8700] Debug — Auth: authenticated user 1 as myusername
Aug 02, 2020 10:52:13.268 [0x1458d1fff700] Debug — Request: [2.48.41.129:29751 (WAN)] GET /library/parts/36778/1572313911/file.mkv?autoAdjustQuality=0&hasMDE=1&location=cellular&mediaBufferSize=209664 (15 live) Signed-in Token (myusername) (range: bytes=11401036355-)
Aug 02, 2020 10:52:13.271 [0x1458d1fff700] Debug — Content-Length of /data/Film/Top Films/A.Movie.i.own2008/A.Movie.i.own2008.mkv is 8103 (of total: 11401044458).
Aug 02, 2020 10:52:13.272 [0x1459012e9700] Debug — Completed: [2.48.41.129:29751] 206 GET /library/parts/36778/1572313911/file.mkv?autoAdjustQuality=0&hasMDE=1&location=cellular&mediaBufferSize=209664 (15 live) 3ms 8103 bytes (range: bytes=11401036355-)
Aug 02, 2020 10:52:13.307 [0x1459012e9700] Debug — Failed to stream media, client probably disconnected after 370596 bytes: 104 - Connection reset by peer
Aug 02, 2020 10:52:13.307 [0x1459012e9700] Debug — Completed after connection close: [2.48.41.129:29784] 206 GET /library/parts/36778/1572313911/file.mkv?autoAdjustQuality=0&hasMDE=1&location=cellular&mediaBufferSize=209664 (14 live) 174ms 370596 bytes (range: bytes=0-)
Aug 02, 2020 10:52:13.345 [0x1459010e8700] Debug — Auth: authenticated user 1 as myusername
Aug 02, 2020 10:52:13.345 [0x1458d3dfe700] Debug — Request: [2.48.41.129:30068 (WAN)] GET /library/parts/36778/1572313911/file.mkv?autoAdjustQuality=0&hasMDE=1&location=cellular&mediaBufferSize=209664 (14 live) Signed-in Token (myusername) (range: bytes=11079-)
Aug 02, 2020 10:52:13.350 [0x1458d3dfe700] Debug — Content-Length of /data/Film/Top Films/A.Movie.i.own2008/A.Movie.i.own2008.mkv is 11401033379 (of total: 11401044458).
Aug 02, 2020 10:52:14.022 [0x1459010e8700] Debug — Auth: authenticated user 1 as myusername
Aug 02, 2020 10:52:14.022 [0x1458d1fff700] Debug — Request: [2.48.41.129:30025 (WAN)] POST /playQueues?includeChapters=1&continuous=0&includeLoudnessRamps=1&repeat=0&extrasPrefixCount=0&type=video&shuffle=0&uri=server%3A%2F%2F9f1ab768e316b9e7d378d9f559fc542f3590a967%2Fcom.plexapp.plugins.library%2Flibrary%2Fmetadata%2F17033&key=%2Flibrary%2Fmetadata%2F17033 (14 live) GZIP Signed-in Token (myusername)
Aug 02, 2020 10:52:14.022 [0x1458d1fff700] Debug — PlayQueue: Converted ‘server://9f1ab768e316b9e7d378d9f559fc542f3590a967/com.plexapp.plugins.library/library/metadata/17033’ to ‘library://x/item/%2Flibrary%2Fmetadata%2F17033’
Aug 02, 2020 10:52:14.023 [0x1458d1fff700] Debug — PlayQueue: 0 generated IDs compressed down to a 20 byte blob.
Aug 02, 2020 10:52:14.026 [0x1458d1fff700] Debug — PlayQueue: Start index: 0 End index: 0 Count: 1
Aug 02, 2020 10:52:14.026 [0x1458d1fff700] Debug — PlayQueue: 1 generated IDs compressed down to a 24 byte blob.
Aug 02, 2020 10:52:14.026 [0x1458d1fff700] Debug — PlayQueue: Added 1 items in 0.0 sec.
Aug 02, 2020 10:52:14.032 [0x1458d1fff700] Debug — It took 0.000000 ms to retrieve 107 items.
Aug 02, 2020 10:52:14.069 [0x1458d1fff700] Debug — Extras: Looking for extras for item com.plexapp.agents.imdb://tt0830515?lang=en with unwatched: 0 fromLibrary: 1 fromTheater: 0 fromBluray: 0 and preroll count: 0.
Aug 02, 2020 10:52:14.069 [0x1458d1fff700] Debug — Extras: Using allowable content ratings: G, PG, PG-13.
Aug 02, 2020 10:52:14.069 [0x1458d1fff700] Debug — Extras: Using genres: Action, Adventure.
Aug 02, 2020 10:52:14.070 [0x1458d1fff700] Debug — Extras: Found 0 extras from library.
Aug 02, 2020 10:52:14.076 [0x1458d1fff700] Debug — It took 0.000000 ms to retrieve 107 items.
Aug 02, 2020 10:52:14.077 [0x1458d1fff700] Debug — We’re going to try to auto-select an audio stream for account 1.
Aug 02, 2020 10:52:14.077 [0x1458d1fff700] Debug — Selecting best audio stream for part ID 36778 (autoselect: 0 language: en)
Aug 02, 2020 10:52:14.077 [0x1458d1fff700] Debug — We’re going to try to auto-select a subtitle.
Aug 02, 2020 10:52:14.077 [0x1458d1fff700] Debug — Audio Stream: 81207, Subtitle Stream: -1
Aug 02, 2020 10:52:14.079 [0x1459012e9700] Debug — Completed: [2.48.41.129:30025] 200 POST /playQueues?includeChapters=1&continuous=0&includeLoudnessRamps=1&repeat=0&extrasPrefixCount=0&type=video&shuffle=0&uri=server%3A%2F%2F9f1ab768e316b9e7d378d9f559fc542f3590a967%2Fcom.plexapp.plugins.library%2Flibrary%2Fmetadata%2F17033&key=%2Flibrary%2Fmetadata%2F17033 (14 live) GZIP 57ms 4981 bytes (pipelined: 2)
Aug 02, 2020 10:52:14.130 [0x1459012e9700] Debug — Auth: authenticated user 1 as myusername
Aug 02, 2020 10:52:14.130 [0x1458d3dfe700] Debug — Request: [2.48.41.129:30025 (WAN)] GET /:/timeline?audioStreamID=81207&bufferedTime=10010&duration=6372875&guid=com.plexapp.agents.imdb%3A%2F%2Ftt0830515%3Flang%3Den&key=%2Flibrary%2Fmetadata%2F17033&playbackTime=119&playQueueItemID=120296&ratingKey=17033&state=playing&time=0&timeToFirstFrame=1 (14 live) GZIP Signed-in Token (myusername)
Aug 02, 2020 10:52:14.130 [0x1458d3dfe700] Debug — Client [3b6a60fbae2ea0dc-com-plexapp-android] reporting timeline state playing, progress of 0/6372875ms for guid=com.plexapp.agents.imdb://tt0830515?lang=en, playbackTime=119ms ratingKey=17033 url=, key=/library/metadata/17033, containerKey=, metadataId=17033, source=
Aug 02, 2020 10:52:14.135 [0x1458d3dfe700] Debug — It took 0.000000 ms to retrieve 107 items.
Aug 02, 2020 10:52:14.189 [0x1458d3dfe700] Debug — It took 0.000000 ms to retrieve 107 items.
Aug 02, 2020 10:52:14.230 [0x1458d3dfe700] Debug — We’re going to try to auto-select an audio stream for account 1.
Aug 02, 2020 10:52:14.230 [0x1458d3dfe700] Debug — Selecting best audio stream for part ID 36778 (autoselect: 0 language: en)
Aug 02, 2020 10:52:14.230 [0x1458d3dfe700] Debug — We’re going to try to auto-select a subtitle.
Aug 02, 2020 10:52:14.230 [0x1458d3dfe700] Debug — Audio Stream: 81207, Subtitle Stream: -1
Aug 02, 2020 10:52:14.232 [0x1458d3dfe700] Debug — [Now] User is myusername (ID: 1)
Aug 02, 2020 10:52:14.232 [0x1458d3dfe700] Debug — [Now] Device is Android (Galaxy S10+).
Aug 02, 2020 10:52:14.233 [0x1458d3dfe700] Debug — [Now] Profile is Android
Aug 02, 2020 10:52:14.233 [0x1458d3dfe700] Debug — [Now] Updated play state for /library/metadata/17033.
Aug 02, 2020 10:52:14.239 [0x1458d3dfe700] Debug — It took 10.000000 ms to retrieve 107 items.
Aug 02, 2020 10:52:14.284 [0x1458d3dfe700] Debug — Photo transcoder: Request for url [/library/metadata/17033/thumb] (is local: 1 upscaled: 0)
Aug 02, 2020 10:52:14.285 [0x1458d2200700] Debug — Webhook: Delivering media.play event by user myusername (1) to 1 hooks.
Aug 02, 2020 10:52:14.286 [0x1458d3dfe700] Debug — Statistics: (3b6a60fbae2ea0dc-com-plexapp-android) Reporting active playback in state 0 of type 1 (scrobble: 0) for account 1
Aug 02, 2020 10:52:14.286 [0x1458f29f4700] Debug — HTTP requesting POST https://scrobblers.trakt.tv/plex/1cf1f1607d4525a9418b940c9e23d92d/20d5d65827fd8bf052ca27d277645013
Aug 02, 2020 10:52:14.288 [0x1459010e8700] Debug — Completed: [2.48.41.129:30025] 200 GET /:/timeline?audioStreamID=81207&bufferedTime=10010&duration=6372875&guid=com.plexapp.agents.imdb%3A%2F%2Ftt0830515%3Flang%3Den&key=%2Flibrary%2Fmetadata%2F17033&playbackTime=119&playQueueItemID=120296&ratingKey=17033&state=playing&time=0&timeToFirstFrame=1 (14 live) GZIP 158ms 492 bytes (pipelined: 3)
Aug 02, 2020 10:52:14.295 [0x1459010e8700] Debug — Auth: authenticated user 1 as myusername
Aug 02, 2020 10:52:14.295 [0x1458d1fff700] Debug — Request: [192.168.10.100:55532 (Subnet)] GET /status/sessions (17 live) GZIP Signed-in Token (myusername)
Aug 02, 2020 10:52:14.295 [0x1458d1fff700] Debug — [Now] Adding 1 sessions.
Aug 02, 2020 10:52:14.296 [0x1459010e8700] Debug — Completed: [192.168.10.100:55532] 200 GET /status/sessions (17 live) GZIP 0ms 4068 bytes (pipelined: 1)
Aug 02, 2020 10:52:15.256 [0x1458f29f4700] Debug — HTTP 200 response from POST https://scrobblers.trakt.tv/plex/1cf1f1607d4525a9418b940c9e23d92d/20d5d65827fd8bf052ca27d277645013
Aug 02, 2020 10:52:18.480 [0x1458d3dfe700] Debug — Request: [127.0.0.1:34436 (Loopback)] GET /identity (21 live) Signed-in
Aug 02, 2020 10:52:18.480 [0x1459012e9700] Debug — Completed: [127.0.0.1:34436] 200 GET /identity (21 live) 0ms 398 bytes (pipelined: 1)
Aug 02, 2020 10:52:22.776 [0x1459012e9700] Debug — Auth: authenticated user 1 as myusername
Aug 02, 2020 10:52:22.776 [0x1458d3dfe700] Debug — Request: [2.48.41.129:30025 (WAN)] GET /:/timeline?audioStreamID=81207&bufferedTime=62580&duration=6372875&guid=com.plexapp.agents.imdb%3A%2F%2Ftt0830515%3Flang%3Den&key=%2Flibrary%2Fmetadata%2F17033&playbackTime=8751&playQueueItemID=120296&ratingKey=17033&state=playing&time=8533 (20 live) GZIP Signed-in Token (myusername)
Aug 02, 2020 10:52:22.777 [0x1458d3dfe700] Debug — Client [3b6a60fbae2ea0dc-com-plexapp-android] reporting timeline state playing, progress of 8533/6372875ms for guid=com.plexapp.agents.imdb://tt0830515?lang=en, playbackTime=8751ms ratingKey=17033 url=, key=/library/metadata/17033, containerKey=, metadataId=17033, source=
Aug 02, 2020 10:52:22.777 [0x1458d3dfe700] Debug — [Now] User is myusername (ID: 1)
Aug 02, 2020 10:52:22.777 [0x1458d3dfe700] Debug — [Now] Device is Android (Galaxy S10+).
Aug 02, 2020 10:52:22.778 [0x1458d3dfe700] Debug — [Now] Profile is Android
Aug 02, 2020 10:52:22.778 [0x1458d3dfe700] Debug — [Now] Updated play state for /library/metadata/17033.
Aug 02, 2020 10:52:22.778 [0x1458d3dfe700] Debug — Statistics: (3b6a60fbae2ea0dc-com-plexapp-android) Reporting active playback in state 0 of type 1 (scrobble: 0) for account 1
Aug 02, 2020 10:52:22.779 [0x1459010e8700] Debug — Completed: [2.48.41.129:30025] 200 GET /:/timeline?audioStreamID=81207&bufferedTime=62580&duration=6372875&guid=com.plexapp.agents.imdb%3A%2F%2Ftt0830515%3Flang%3Den&key=%2Flibrary%2Fmetadata%2F17033&playbackTime=8751&playQueueItemID=120296&ratingKey=17033&state=playing&time=8533 (20 live) GZIP 2ms 492 bytes (pipelined: 4)
Aug 02, 2020 10:52:23.582 [0x1459012e9700] Debug — Completed: [192.168.10.100:55525] 200 GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cmirror%2Cplayqueues&timeout=1 (25 live) GZIP 20000ms 5 bytes (pipelined: 1)
Aug 02, 2020 10:52:23.596 [0x1459010e8700] Debug — Auth: authenticated user 1 as myusername
Aug 02, 2020 10:52:23.596 [0x1458d1fff700] Debug — Request: [192.168.10.100:55532 (Subnet)] GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cmirror%2Cplayqueues&timeout=1 (24 live) GZIP Signed-in Token (myusername)
Aug 02, 2020 10:52:23.596 [0x1458d1fff700] Debug — Content-Length is -1 (of total: -1).
Aug 02, 2020 10:52:23.666 [0x1458d3dfe700] Debug — Request: [127.0.0.1:34454 (Loopback)] GET /identity (25 live) Signed-in
Aug 02, 2020 10:52:23.666 [0x1459010e8700] Debug — Completed: [127.0.0.1:34454] 200 GET /identity (25 live) 0ms 398 bytes (pipelined: 1)
LOG for streaming WITHsecure connection (REMOTE CONNECTION) (MOBILE APP)
NOT WORKING
Aug 02, 2020 11:34:53.935 [0x147b3eeb7700] Debug — Auth: authenticated user 1 as myusername
Aug 02, 2020 11:34:53.935 [0x147aeedf6700] Debug — Request: [2.48.41.129:29739 (WAN)] GET /library/metadata/20785?includeChapters=1&includeLoudnessRamps=1&includeMarkers=1&includeRelated=1 (11 live) TLS GZIP Signed-in Token (myusername)
Aug 02, 2020 11:34:53.937 [0x147aeedf6700] Debug — We’re going to try to auto-select an audio stream for account 1.
Aug 02, 2020 11:34:53.937 [0x147aeedf6700] Debug — Selecting best audio stream for part ID 43561 (autoselect: 0 language: en)
Aug 02, 2020 11:34:53.937 [0x147aeedf6700] Debug — We’re going to try to auto-select a subtitle.
Aug 02, 2020 11:34:53.937 [0x147aeedf6700] Debug — Audio Stream: 99130, Subtitle Stream: -1
Aug 02, 2020 11:34:53.939 [0x147b3eeb7700] Debug — Completed: [2.48.41.129:29739] 200 GET /library/metadata/20785?includeChapters=1&includeLoudnessRamps=1&includeMarkers=1&includeRelated=1 (11 live) TLS GZIP 4ms 1870 bytes (pipelined: 1)
Aug 02, 2020 11:34:53.959 [0x147b3f0b8700] Debug — Auth: authenticated user 1 as myusername
Aug 02, 2020 11:34:53.959 [0x147aeedf6700] Debug — Request: [2.48.41.129:30336 (WAN)] GET /video/:/transcode/universal/decision?audioBoost=100&autoAdjustQuality=0&directPlay=1&directStream=1&directStreamAudio=1&fastSeek=1&hasMDE=1&location=cellular&maxVideoBitrate=200000&mediaBufferSize=74944&mediaIndex=0&partIndex=0&path=%2Flibrary%2Fmetadata%2F20785&protocol=&session=3b6a60fbae2ea0dc-com-plexapp-android&subtitleSize=100&videoBitrate=200000&videoQuality=100&videoResolution=3840x2160 (11 live) TLS GZIP Signed-in Token (myusername)
Aug 02, 2020 11:34:53.959 [0x147aeedf6700] Debug — Found session GUID of 3b6a60fbae2ea0dc-com-plexapp-android in session start.
Aug 02, 2020 11:34:53.961 [0x147aeedf6700] Debug — TranscodeUniversalRequest: using augmented profile Android
Aug 02, 2020 11:34:53.961 [0x147aeedf6700] Debug — Downloading document http://127.0.0.1:32400/library/metadata/20785?includeBandwidths=1&offset=-1&X-Plex-Incomplete-Segments=1&X-Plex-Session-Identifier=3b6a60fbae2ea0dc-com-plexapp-android
Aug 02, 2020 11:34:53.962 [0x147aeedf6700] Debug — Auth: authenticated user 1 as myusername
Aug 02, 2020 11:34:53.965 [0x147aeedf6700] Debug — We’re going to try to auto-select an audio stream for account 1.
Aug 02, 2020 11:34:53.965 [0x147aeedf6700] Debug — Selecting best audio stream for part ID 43561 (autoselect: 0 language: en)
Aug 02, 2020 11:34:53.965 [0x147aeedf6700] Debug — We’re going to try to auto-select a subtitle.
Aug 02, 2020 11:34:53.965 [0x147aeedf6700] Debug — Audio Stream: 99130, Subtitle Stream: -1
Aug 02, 2020 11:34:53.966 [0x147aeedf6700] Debug — Streaming Resource: Reached Decision id=20785 codes=(MDE=1000,Direct play OK.) media=(id=40639 part=(id=43561 decision=direct play protocol=* streams=(Video=(id=99129 decision= width=1280 height=720) Audio=(id=99130 decision= channels=0 rate=0))))
Aug 02, 2020 11:34:53.967 [0x147b3f0b8700] Debug — Completed: [2.48.41.129:30336] 200 GET /video/:/transcode/universal/decision?audioBoost=100&autoAdjustQuality=0&directPlay=1&directStream=1&directStreamAudio=1&fastSeek=1&hasMDE=1&location=cellular&maxVideoBitrate=200000&mediaBufferSize=74944&mediaIndex=0&partIndex=0&path=%2Flibrary%2Fmetadata%2F20785&protocol=&session=3b6a60fbae2ea0dc-com-plexapp-android&subtitleSize=100&videoBitrate=200000&videoQuality=100&videoResolution=3840x2160 (11 live) TLS GZIP 7ms 1786 bytes (pipelined: 1)
Aug 02, 2020 11:34:55.740 [0x147aeedf6700] Debug — Request: [127.0.0.1:55584 (Loopback)] GET /identity (13 live) Signed-in
Aug 02, 2020 11:34:55.740 [0x147b3f0b8700] Debug — Completed: [127.0.0.1:55584] 200 GET /identity (13 live) 0ms 398 bytes (pipelined: 1)
Aug 02, 2020 11:34:59.638 [0x147b3eeb7700] Debug — Completed: [10.10.20.201:57842] 200 GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cmirror%2Cplayqueues&timeout=1 (12 live) TLS GZIP 20000ms 5 bytes (pipelined: 1)
Aug 02, 2020 11:34:59.650 [0x147b3f0b8700] Debug — Auth: authenticated user 1 as myusername
Aug 02, 2020 11:34:59.650 [0x147aeedf6700] Debug — Request: [10.10.20.201:57856 (Subnet)] GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cmirror%2Cplayqueues&timeout=1 (12 live) TLS GZIP Signed-in Token (myusername)
Aug 02, 2020 11:34:59.650 [0x147aeedf6700] Debug — Content-Length is -1 (of total: -1).
Aug 02, 2020 11:35:00.905 [0x147aeedf6700] Debug — Request: [127.0.0.1:55598 (Loopback)] GET /identity (13 live) Signed-in
Aug 02, 2020 11:35:00.905 [0x147b3f0b8700] Debug — Completed: [127.0.0.1:55598] 200 GET /identity (13 live) 0ms 398 bytes (pipelined: 1)
Aug 02, 2020 11:35:06.085 [0x147aeedf6700] Debug — Request: [127.0.0.1:55600 (Loopback)] GET /identity (13 live) Signed-in
Aug 02, 2020 11:35:06.086 [0x147b3f0b8700] Debug — Completed: [127.0.0.1:55600] 200 GET /identity (13 live) 0ms 398 bytes (pipelined: 1)
Aug 02, 2020 11:35:11.227 [0x147aeedf6700] Debug — Request: [127.0.0.1:55602 (Loopback)] GET /identity (13 live) Signed-in
Aug 02, 2020 11:35:11.227 [0x147b3f0b8700] Debug — Completed: [127.0.0.1:55602] 200 GET /identity (13 live) 0ms 398 bytes (pipelined: 1)
Aug 02, 2020 11:35:14.030 [0x147b3f0b8700] Debug — CERT: incomplete TLS handshake: stream truncated
Aug 02, 2020 11:35:16.368 [0x147aeedf6700] Debug — Request: [127.0.0.1:55604 (Loopback)] GET /identity (12 live) Signed-in
Aug 02, 2020 11:35:16.368 [0x147b3eeb7700] Debug — Completed: [127.0.0.1:55604] 200 GET /identity (12 live) 0ms 398 bytes (pipelined: 1)
Hope someone has some input…
I started to get this recently from my work’s network and yet it works fine from elsewhere. I’m still trying to figure out the issue but I think it might be related to DNS rebind settings and believe it’s possibly something that has been changed on my work network as opposed to my local network at home. Although saying that I did change router at home but cannot see anything wrong with it’s config and I haven’t actually been in work since March so anything could have been changed at work in that time.
Just to add to that it has never worked from my work’s WiFi network and so I think it’s probably something they had in place on the WiFi that is now in place on the wired side too.
One work around is to check which port your server is using externally and connect to it’s IP with that port number. You will get a warning that the certificate is invalid but it will work and be secured. Obviously though this only helps if you are using a web browser though. :frowning:
