Remote Access keeps disconnecting
The remote access will connect and about 30-45 seconds later it will turn red and say Not available outside your network. Not sure why this is doing this because it has always worked before. Its been in the last several months it started doing it. Has anybody else have this problem? If so, were you able to fix it and how did you do it
Server Version#:Version 1.35.1.2632-c6783c78
Exactly the same for me! Been like this the last 3 months.
Same issue for me, I am running Plex off an iMac through tenda mesh
Same here. It will say I have internet for 30 seconds and then go red. Everything keeps functioning as expected, but is super annoying because you think there is always a problem.
Same issue remote access is very unstable. I have opened my port and created a fixed IP for my server machine.
I also constantly get “indirect” warnings even when I just on another machine in my house.
I got the same issue starting tonight, nothing has changed on my side, I don’t know how to fix this
I’m having the same issue.
EDIT: I found and fixed my issue. It was my GeoIP filtering and blocking incoming connections from outside the United States that was causing the issue.
