Remote access kimsufi
Server Version#: Version 1.19.4.2935
Debian 9.12
Hello,
I would request some help as I am now stuck since some days.
Status
  • plexserver installed in a kimsufi dedicated server : KS-10 Intel i5-2300
  • Installation is done
  • Connection with putty to configure the server => OK
  • Check that the server is accessible from outside : “Server fully accessible from outside” => OK
    • port 32400
  • I close putty
  • Connect to the server : ip.server/web => OK
  • Connect to app.plex.tv => KO
    It says : server is currently unavailable
  • Connect threw Android application => offline
Do you have any adea why I have this issue. What I missed in my configuration.
It is currently using standart apt installation
I have tried with iptable deactivated
I have tried when connected in “tunnel” mode to disconnect and reconnect
I have tried other installation with docker and same issue
So now I am blocked.
Thanks in advance for any help / ideas I could explore
from a different PC on the same network go to canyouseeme.org and test the port you have setup for remote access default is 32400 and see what it shows.
Thanks for your answer.
I have checked from my with https://openport.net/
Domain : XX.XX.XX.XX on Port 32400 is Close
Test done from my home. Domain XX is the IP of my dedicated server.
So it means it looks closed.
I tried to understand why it is closed but could not found the reason. Any idea how to check what is blocking this port ?
Edit:
I did an additional check with https://www.portcheckers.com/
91.121.XXX.XXX :arrow_right: Port 32400 Open
And again from outside
I can access to XX.XX.XX.XX:32400 but app.plex.tv is not working
