Server Version#: 1.19.5.3112
Player Version#: 4.34.3
I am using Nvidia Shield with 2TB external SSD as my server.
My router is Sagemcom and set up port forward.
Remote Access once turns to green 1 second and turns red.
I cannot figure out what is wrong.
If I change my router, will it help?
nokdim
August 2, 2020, 12:39am
2
Why do you have 2 port forwards?
I would suggest you delete the port 0 one and leave the 32400 one.
after goto canyouseeme.org and test for success on that port.
Thank you for your kind advice!
I followed your direction and canyouseeme.org says Sucess but still remote access doesn’t work.
It drives me crazy.
nokdim
August 2, 2020, 4:28am
4
Try restarting Plex now that you removed that port forwarding. You can reboot the shield.
And I am assuming it still shows red under remote access?
After a reboot check remote access again.
It worked! Thanks a lot!!!
