Server Version#: 1.32.6.7557
Player Version#: 1.32.6.7557
Just updated today and my remote access stopped working. (it was working fine previously)
My plex is running in a docker container with tcp 32400 exposed. When I run netstat on the hostOS i do not see any listening ports on port 32400
Router configs did not change from before and port 32400 is forward to the natted IP where plex is hosted
logs show
Oct 06, 2023 18:18:54.522 [140153224133432] WARN - [HttpClient/HCl#138] HTTP error requesting GET https://xx-xx-xx-xx.5f179f19790d4f879c8fb55e15efd375.plex.direct:32400/identity (7, Couldn't connect to server) (Failed to connect to 99-20-107-157.5f179f19790d4f879c8fb55e15efd375.plex.direct port 32400 after 0 ms: Couldn't connect to server)
netstat shows
$ netstat -an | grep 32400
docker ps
2ea12cb21199 plexinc/pms-docker:latest "/init" 23 minutes ago Up 22 minutes (healthy) 8324/tcp, 1900/udp, 32410/udp, 32400/tcp, 32412-32414/udp, 32469/tcp plex
I am having the same issue with Plex running on a CentOS 7 VM in ESXi 6.7. Plex was running fine until ESXi server crashed and now I have the same issue with nothing listening on port 32400. I have tried restarting the VM and also restarting the plexmediaserver service, but neither resolves the issue.
[root@beachwood-plex dale]# ps -ef | grep plexmediaserver
plex 2169 1 0 12:17 ? 00:00:00 /usr/lib/plexmediaserver/Plex Media Server
I was having the same issue with port 32400 but was able to get around it by setting up a reverse proxy on my Synology NAS and then pointing the Plex server to use that URL in settings instead of their remote access relay. You can setup a reverse proxy with CentOS 7 via apache, there are instructions online, youâll just need to create a DDNS (if you donât already have one) so you can create the proxy and access the Plex server remotely from anywhere⊠Once you get that URL working log into your Plex server, go into Settings->Network, and then paste the URL into âCustom server access URLâsâ and that should do the trick. Full disclaimer: I donât know much about Linux so this is probably as much as I can offer at this point. Good luck!
