Remote Access not working
The Remote Acces is “not available” but works very slowly.
When i try to turn it on, it gets activated for a second, then it deactivates again.Unbenannt.PNG|690x339.
My internet provider (1&1, germany) only gives me “DS-Lite”. (=no public ipv4 adress, only public ipv6 adress).
Are you hosting your Plex through a hosting provider? If so, they might have blocked the port so try manually changing it. You also may have to allow it through the firewall as well.
It won’t work with non-valid IP address and I don’t think Plex supports ipv6
No i am Hosting it myself.
I need ipv6 to access my router, but every flatrate in Germany only supports ipv4.
You have DS-Lite, so it’s the usual story like with all the other millions of users with that:
  • connectivity over IPv4 is through CG-NAT, so no direct access
  • connectivity over IPv6 technically works, just open port 32400 in the router firewall. You’ll have to set it up manually with Plex (own domain name + cert), and of course the clients also need to be on IPv6.
If you can get your ISP to move you back to single stack IPv4 with a public ip address, that’s a workaround until Plex has added automatic IPv6 support. To speed that up (it’s been seven years now), vote for this: https://forums.plex.tv/t/ipv6-support-for-myplex/
